New Audio Rack
I've finally reached the point that it's time to upgrade to a larger audio rack. The old one I built is completely out of room. (Yea I don't even bother feeding the cables through the center column anymore.lol) l7h8m7q5owue.jpg
So after stumbling across this website
http://audiofederation.com/audiophiles-guide/high-end-audio-racks I found one that I wanted to mimick. cm99cml1bhwo.png
Mine is going to be twice as beefy and will have 4 legs rather than 3. I'm going to reconfigure the program that I had for machining Larry's 1.2tl caps and make 24"x 24"x .75" aluminum shelves that'll sit on top of the spikes. After that the rest is lathe and laser work so it should go fairly fast.ieuas2v0juc4.jpg
Any suggestions on some add on's?
    EndersShadow Posts: 17,719
    Larry has a CNC plan for the rack he built for himself that sounds like you described
  • lightman1
    lightman1 Posts: 10,797
    Because...if I'm not mistaken... Brian and Larry work together, dipshiit!
    edited July 2017
    lightman1 wrote: »
    Im aware but it's been a few years (6 to be exact) since Larry built it so I don't know if Brian was around then....
    Dill pickle sloberer....
    http://forum.polkaudio.com/discussion/125475/building-my-own-audio-equipment-rack/p1
  • lightman1
    I know where you live, Dan.....
    msg Posts: 10,458
    Exciting project, Brian!
    No suggestions, other than a consideration for two shorter units as opposed to one tall? Or will each 'shelf' be modular and able to be stacked in any configuration? I'll be following along on this one. You fab guys make me jealous!
    Noticed some interesting bits in/on your turntable. Care to detail on this or another thread?
    lightman1 wrote: »
    Then stop on by and lets hang out lol......
    Toolfan66 Posts: 18,160
    Brad Pit says Rule #1 we don't talk about Turntables...
    F1nut Posts: 51,945
    Two suggestions. One, get rid of that Monster power conditioner and two, don't paint the rack red.
    xschop Posts: 5,347
    A challenge would be to incorporate the drop-offs into the design.
    Watching the light show from the back patio and had to chime in. Nice project....Happy 4th everyone.
    txcoastal1 Posts: 13,519
    edited July 2017
    Happy 4th bro
    msg Posts: 10,458
    You're ditching the music note symbol in the frame, right? Replacing it with something tough, like a biohazard emblem, or Tap-Out or No Fear logo?
  • vmaxer
    vmaxer Posts: 5,120
    Red is the new black.
    And you know black can't be had.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • @msg this thing will have different sized spacers 6,8, and 10". And I'm not putting anything in the center sadly. That aluminum plate will cover it up.
    @F1nut yea I'm done with the red theme. Lol this winter I'm overhauling my 2b's. Goin' back to black.
    msg Posts: 10,458
    Toolfan66 wrote: »
    Jesse Durden says Rule #1 we don't talk about Turntables...
    Further...
    "You are not special. You are not a beautiful and unique snowflake." - Jesse Durden; Paper St. Cable Factory, circa 2017
  • afterburnt
    afterburnt Posts: 7,892
    Nice rack! Do you have a John Travolta ghost?
    That's Brad Pitt and Edward Norton..
  • afterburnt
    edited July 2017
    Toolfan66 wrote: »
    Damn he has two celebrity ghost, nice! But we are not supposed to talk about that.
    Almost done! Im just waiting for the 1.5" round stock to come in on Wednesday. I switched from aluminum shelves to clear acrylic. It's like $250 cheaper, and far better looking.
    WOW!! Stuck around a little this afternoon... :)
    msg Posts: 10,458
    Dayam. That acrylic looks FAT! I like it! How thick are those shelves, anyway? You gonna do little edge lights in the rear to make them glow, or anything like that?
  • msg wrote: »
    They're .75" thick.
    I'm not sure yet. If I do I'd like to find a way that only illuminates the shelves and doesn't leak light anywhere else.
    msg Posts: 10,458
    Toolfan66 wrote: »
    Larry, I thought you just threw that reference out there. I completely missed the Fight Club print altogether, initially. dehrrr. Just now seeing it! I was distracted by those TT details...
  • muncybob
    muncybob Posts: 3,262
    Where's Brian?
    Yep, my name really is Bob.
    pitdogg2 Posts: 27,233
    No doubt what happened?
    F1nut Posts: 51,945
    Strange....
