new system - vocals a bit subdued............. (ideas)
Hi, I was referred to this forum as a great place for learning / information. I just purchased a great system used. It is a Plinius Integrated, PrimaLuna tube CD player and a pair of Paradigm Signature S4 speakers. This equipment replaced an all Rega system.
There is a lot more information on my new system, and it sounds great..... but it seems like the vocals are a bit flat, or subdued...... I have good cables, etc., so just curious if there is something I should try to switch up. Any ideas?
  • mikeyb128
    mikeyb128 Posts: 2,885
    Do vocals sound subdued with just the CDP or through all inputs?
    2 channel:
    Theater:
  • jolson72
    jolson72 Posts: 46
    Mikeyb128, just tried a Diana Krall CD on two CD players: Primaluna tubed and a rega Planet.... The vocals just seem a little bit flat... Not quite as high and crisp as they should be.... Try different speaker cables?
  • Nightfall
    Nightfall Posts: 10,084
    Did you always have the Paradigms or did you have Rega speakers before?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • jolson72
    jolson72 Posts: 46
    Nightfall: Just got the Paradigm speakers. The new system has a lot more information... But the high vocals just seem a little flat...... And I was using an old beat up pair of KEF speakers, as they sounded better than the Rega speakers I had.
  • Nightfall
    edited June 2017
    Do you still have the any of the other speakers to compare? It might just be that you don't like the Paradigm sound would be my guess. Cables will make a difference, but not large enough to go from recessed midrange to forward midrange IMO more for final tweaking.
    afterburnt wrote: »
  • jolson72
    jolson72 Posts: 46
    Nightfall: will do a test in a bit. What is a good CD / artist to test vocals with?
  • Nightfall
    I'd imagine Diana Krall is already a good choice.
    afterburnt wrote: »
  • marvda1
    marvda1 Posts: 4,937
    what are your cables? what are the tubes in the cd player?
    Puritan PSM156
  • jolson72
    jolson72 Posts: 46
    Marva1: CD player is a Primaluna Prologue 8 with the stock tubes. The Rega Planet I have sounds similar. Cables are Siltech SQ-110 Mk 2 interconnects and Siltech
    LS-88 speaker cables that came with the system.
    F1nut Posts: 51,680
    edited June 2017
    What brand/type are the stock tubes?
    The Rega CDP has a very laid back top end.
  • Nightfall
    Steve Hoffman on tube rolling in a PrimeLuna preamp
    Lee, believe it or not, I went this route with my Primaluna preamp. I mucked around for weeks with NOS tubes.
    Guess what? It sounded the best with the stock tubes that came with it. I asked Kevin Deal about that. He said (what I always say) that they voice the gear with the same tubes that they sell it with so it should sound the best that way...
    Whether or not the same applies to their CD players I don't know.
    afterburnt wrote: »
    txcoastal1 Posts: 13,499
    Overall it just strange to me. Couple pairs of Paradigms I've heard, I would have never thought of them as laid back. I like the Rega CDP, and the Plinius. Just wondering if it's the synergy as a whole. Do you have any local friends with another integrated, or a system you can take your speakers to, to get another opinion.
    https://www.paradigm.com/downloads/UAV_S4_C3_Servo_Review.pdf
    The only significant aberration in these
    measurements is the relatively high tweeter
    output from both speakers. The curves
    suggest that they may sound forward in
    the upper registers. FM did note this in
    his listening tests. The relatively smooth HF
    response (apart from the overall elevated
    level) suggests that it might be corrected by
    simply padding down the tweeter by 2-3 dB,
    or using a judicious hand on a treble control,
    without obscuring the impressive sound that
    Fred reports.
    – Thomas J. Norton
  • jolson72
    jolson72 Posts: 46
    txcoastal1 : I will try that tomorrow. I have a Rega Mira integrated. I'll hook it up to the Paradigms and see if the sound quality, or highs, is that different.....
    Also, from the review you posted: It seems that most people use the S4 speakers in a home theater environment. The speakers are every bit as good for use in a 2 channel setup, correct?
    I'd rather use them in 2chnl than HT...IMHO
    ...don't be discouraged, sometimes no matter how good a speaker is, it may not be your cup-o-tea
  • jolson72
    jolson72 Posts: 46
    TX, thanks for the response, again. It was a huge jump going from a Rega Mira, Rega Planet and Rega speakers to the Plinius, Primaluna and Paradigm speakers. It might take me a bit of time to get used to the difference. This is the first time I have had such an expensive, revealing system. So, I might just be hearing a lot more.....
    Also, what are your thoughts on power cables? When I bought my system, it came with a quite expensive Siltech Ruby Hill powercord.... Seems like I should sell it, and put the money to use somewhere else.... There are a few Audioquest powercables I got as well, which I'll probably stick with. Fun to listen and try to figure it out, however.
    I am a cable proponent, but I do not make recommendations unless you have the same gear as I. I have a tub of cables from different manufactures, some expensive some not so much. Have had to many surprises, and use the cables for final tweaks.
    Been hanging with to many people playing with cables and found cables work in mine but not yours and vice-versa.
    At this point I don't think cables are your issue. I think change is...but it sounds like you still have your original gear so swapping around is kinda the fun part till you get the system dialed in. Sounds like a good time if you are just hanging out for 4th of July weekend :)
  • tratliff
    tratliff Posts: 1,763
    Sometimes such a dramatic change is difficult to get use to.
    I would give it some quality time and then make a decision on whats next.
    Makes me wonder if its just the complete change in house sound and what your previous system was capable of.
    Listen to some music that you know well. Don't compare it to the old system but listen for what the new system brings. You may find that the laid back or flat vocals are more to your liking once it settles in.
    tonyb Posts: 33,066
    Seems to me....the S4's and that brand are not laid back in the top end. I would suspect since he bought them used maybe something got damaged in transit. Maybe they've been worked on before and the previous owner changed some values in the crossover to tame them down to his liking.
    I might take a look see at the crossovers and see if they are stock, been worked on, or if anything looks burnt up, out of whack. Put your ear to the tweeters at low volume and make sure they are working, they may not even be the originals.
  • jolson72
    jolson72 Posts: 46
    Interesting.......... I guess I figured an expensive tube C.D. player would vastly sound better than my Rega Planet C.D. player. Did a sound test today. Same amp, same cables, same speakers..... The Rega C.D. player has more top end, and more information than the PrimaLuna C.D. player. My wife agreed that the Rega player sounds better. I guess in my system, the player that is 1/3 the price works better. Surprising. Next will be trying a Kimber PBJ, Rega Couple and Siltech SQ-110 interconnect comparison to see which I prefer there.
  • mikeyb128
    jolson72 wrote: »
    Although I have no experience with the PrimaLuna, I wouldn't jump to that conclusion so quickly. Some tube rolling could benefit that CD player, it could have tired tubes, or some cheapie Chinese or Russian tubes. I would experiment with tube rolling, be careful though, it's addicting and fun.
    2 channel:
    Theater:
    Rega has been building quality CDP's much longer than Prima Luna has even existed.
    There might be a higher signal output voltage than the PL also.
  • jolson72
    jolson72 Posts: 46
    Ugh. Don't know that I have any interest in tube rolling, etc. I just want to turn it on and enjoy it. And honestly, I like the top loading / non mechanical nature of the Rega better than a tray. Maybe I'll upgrade the Planet to a Jupiter and be happy? Also, it's amazing how close the Rega Mira sounds to the Plinius 9200. Says a lot about the quality of Rega equipment, I guess.
  • kharp1
    kharp1 Posts: 3,453
    I've owned several pair of Paradigm speakers over the years (still have 2 pair I use outdoors) and a laid back mid to high end is not remotely how I would describe them. I might would roll a set up tubes (not sure what the Primaluna uses) that are geared more for pronounced uppers an see what that does for you.
  • codycatalist
    codycatalist Posts: 2,662
    I agree, try some different tubes and see what you like. We all would like plug n play but switching out your tube is as simple as pulling out and putting a new one in. I have had some tubes that seem completely veiled and others bright and detailed in the highs.
  • machone
    machone Posts: 1,552
    :D
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    tonyb Posts: 33,066
    jolson72 wrote: »
    That's a shame, then I'd suggest not owning any tubed gear as rolling comes with the territory. The whole purpose of rolling tubes is to find the sound you like and synergy with your system. Sell it and stick with Solid State gear.
    Since you like Rega, move up their ladder. Though I don't know why in todays age anyone would want to drop big bucks on a cdp. I might be more inclined to go digital, have all your music at your fingertips, and be able to stream it all over the house for the same price as one higher end cdp.
    If a cdp floats your boat though, buy used and save some coin.
  • decal
    decal Posts: 3,205
    tratliff wrote: »
    ^^^^^ This ^^^^^
  • Jaybeez
    Jaybeez Posts: 748
    Lots of variables, including gear, cables and other factors. Better gear reveals flaws in recordings that you may not have heard before. I noticed a bit more mid-range to familiar recordings when I upgraded to a Plinius integrated (9100). If this holds true for your model, you may sense a bit less high end "sparkle" because the balance between mid and high that you are accustomed to has changed. I'd give it some time then decide, as noted previously. I'm at the point where I almost can't listen to anything unless it's ruler flat, in contrast to 30+ years of listening to gear in what my sound engineer buddies call the EQ "smile".
    2 Channel "Polk" Room:
    Marantz PM8004 Integrated
    Marantz SA8004 SACD Player
    WiiM Mini
    Polk 7B with RDO198s
    billbillw Posts: 7,468
    I'd take the advice above from Tony and really check the speakers out for proper function. All the Paradigm I've heard are not laid back. Could be bad tweeter, bad xover. I really don't think cable swaps will get you where you want with this system.
    Although...looking at this review and frequency response, maybe they are a bit laid back through the upper midrange...
