Receiver advise for T series
Hi guys,
So i'm from peru, and there's a store starting a deal with Polk, so for their initial container they are going almost at the same price as USA. (which is pretty amazing and will have local warranty)
So, i'm bulding a budget home theater room, right now i only got my proyector which is an Epson HC 2045.
My room size is 4meters x 6 meters (13x19 fts)
So far i been thinking about:
4x T15 F/R
1x T30
1x PSW10
which Receiever should i buy ?? The cheapest one i can get is just fine ? like a Denon AVR-S510BT?
Thanks,
  • mrloren
    mrloren Posts: 2,471
    I would look for a Pioneer VSX-831 or VSX-1131. Onkyo still has an HDMI board issue and Sony has a heat sensor problem. Yamaha are nice too.
    I don't know about using a lower end Denon, I know Pioneer lower end are decent.
  • rooftop59
    rooftop59 Posts: 8,121
    edited June 2017
    Welcome to cp! And congrats on the upcoming purchase!
    Personally I have greatly preferred the sound of denon over pioneer. Entry yamahas can be harsh and bright sounding (though I am a big fan of the rx-a line). A marantz nr series would also be an excellent entry level choice, but might be pricier and not available.
    What other options do you have?
    Game Room 5.1.4:
    Bedroom 2.1
  • Thank for your answers guys, as far as i know i can get a Denon, Yamaha, Marantz, Pioneer locally, Sony ill have to look around or import it from usa.
    For example i can get the Marantz from mrloren signature for just $250 xtra of the amazon price. thats $1166 locally, but the Yamaha v581 ($329 at amazon) cost me $676 in Peru, or $540 if i import by myself... a Denon X1300W $750.
    Or i could just import a Denon S520 for $350...
    By the way peruvian electric outlets are 220v, if i import the unit from usa ill have to use a transformer, and the guy from the store says this will make the unit have less lifespam (i once fried a ps1 because of this :disappointed: )
    My speaker setup is going to cost me around $500-600, so how much should i spent on the receiever ??
    It could be nice, to have 7.2 and wifi, and get a pair of T50s in the future.... but should i spent more on the receiever than speakers ?
  • speakers make the most difference in sound quality.. get the best speakers you can afford. spend the rest on your receiver and cables.. so 70 % of your budget or so should go to the speakers.
    denon makes a nice product.. i have heard some denons in that 300 dollar price range with nice speakers and i though they sounded very good. i do know know about the life span and 220v outlets and a transformer. seems like they would have a denon model around that price in your conutry.
    Cambridge Azur 651A
    Polk LSi M703
    Sonos Connect
  • mrloren
    edited June 2017
    ^^^ a AVR made for 220, I had friends in the Army who said all their electronics would toast off using the transformers within a year.
    If your planing on going to 7.1 in the future I would look for a Denon, Yamaha
    RX-AXXXX or Pioneer 7.1 receiver to start. I do like my Marantz but that looks to be more costly for you.
