Recommend me a Sound Bar
kevhed72
kevhed72 Posts: 5,152
We are turning out dining room we never use into a dedicated TV room....simple, minimalist room for TV and everyday music streaming. Just some constructive feedback to Polk...searching for products online needs to be a cleaner, to the point experience. I understand how the website is set up....but too many clicks to find what you want. Back to my question.....looking for any experience with surround bars out there? Looking for wireless speakers/sub and ability to connect DirecTV and Netflix. Simple and minimal wires. The surround bar can sit on a consol right under the TV. Separate surround speakers not a necessity....current or past models are OK...
  • motorhead43026
    motorhead43026 Posts: 4,018
    edited June 2017
    I would hold off until September and get the new Magnifi Max SR with SDA.
    I have the Magnifi Minis which I really like, but I will probably get the new for my main tv.
    – Kevin Alfred Strom
    The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm.
  • Derf
    Derf Posts: 229
    kevhed72 wrote: »
    ...looking for any experience with surround bars out there...current or past models are OK...
    I currently use the Polk SB 9000, TOL from a few years back. Only problem is dialogue, when there is background noise present such as music or fans cheering, is almost inaudible. I called Polk about it, and TS said the new sound bars with "voice adjust" have fixed this problem. So I'm also waiting on the new Magnifi Max to come out and I'm going to try that one.
    Integrated Amp: Marantz PM-10
    Speakers: Usher MD2
    Subwoofer: Rythmik F15HP
    DAC: North Star Design Supremo
    Streaming Source: AURALiC Aries Mini
    SACD Player: Marantz SA8004
    Power Source: PS Audio PP3 on dedicated 20amp circuit
  • erniejade
    erniejade Posts: 6,321
    Check out what klipsch has to offer.
  • mantis
    mantis Posts: 17,552
    Both Heos and Sonos make awesome sound bars for both music and TV watching.
    Dan
