AVR Source Switching problem
Whenever I turn on my Marantz 1403 AVR to watch TV, I have to turn on the Cable box ( DIRECTV) & wait till my TV fully turns on before I turn on then AVR. If I don't do it in that order, I won't have sound and/or picture & I have to reset the AVR to correct this. I have not had this problem with any other AVR. I'm not sure if this AVR operates differently or if I have a faulty one. I bought it used so not sure if the previous owner blew something out or if this is normal. No problems anywhere else on the unit. The AVR does not usually do this in cd play, although i have had to restart it when switching over to play CDs.
So I'm asking, is this normal? Not a big deal, just feels like I'm doing it wrong everytime I turn the #*@% thing on.
- L200 Legends (Black Oak)
- SDA 2B (1989, Oak Tops, 194s, Spikes)
- Monitor 7B (1982 Peerless, Sonicaps, Mills, Binding Posts)
- (2) SVS SB12-NSD (Flat Black)
- SVS SB 3000 (Gloss Black)
- CSi A6 Center (Cherry)
- Pioneer SC-1222K (7.1 AVR)
- Marantz MM 7055 (5 Ch Amp)
- Pioneer PD-D6 SACD Player
- Marantz NR1403 (5.2 AVR)
- Sony UBP-X800M2 (4k Blu-ray)
- Sony UBP-X1100ES (4K Blu-ray)
- Adcom GFA 555 Amp
- Monitor 5 (194s, Side Surrounds)
- Monitor 5Jr+ (194s) {Storage}
- LG OLED65CXPUA (4K OLED TV)
- LG 55UN7300PUF (4K HD TV)
- RT35i (Cherry)
- (2 Pair) RT25i (Cherry)
- CS400 (Center)
- CS350 (Center)
- F/Xi A4 (Rear Surrounds)
- RT25 (Rear Surrounds) {Storage}
- Audioquest Interconnects
- Blu-Jean Speaker Cables & Interconnects
" But boy do I remember the strain of her refrain " LG
    No, it's not normal. That said, have you read the manual and made sure all your settings are correct ?
  • polrbehr
    polrbehr Posts: 2,868
    Depending on what type of HDMI cable you're using (assuming that's the issue, it happened with my Denon 3312ci on occasion), maybe try upgrading that?
    I went with an Audioquest Cinnamon* cable and haven't had a problem since
    >>knocks on forehead<<
    * not advocating this particular brand, just reporting the success I've had with it *
    polrbehr wrote: »
    Possible, an out of date HDMI cable will create handshake issues. Make sure you have a current HDMI series of cable. There were many different iterations, the older ones won't work correctly with modern gear.
    polrbehr wrote: »
  • polrbehr
    ^^^ Heard ya the first time...
    LOL, not just older, the one I originally had in the mix was a bottom-rung
    HDMI from monoprice, IIRC I think the 6' was about $4.99? The AQ was a very
    noticeable step up in both PQ & SQ.
  • TCK
    TCK Posts: 231
    I have AQ cinnamon too. Both connecting the cable box to the amp & amp to the tv. I'm assuming they are up to date, as they are rather new but I will check into that. This sounds like the most logical solution. Thanks guys!
    - Adcom GFA 555 Amp
    - RT35i (Cherry)
    - CS400 (Center)
    - CS350 (Center)
  • polrbehr
    If they are fairly new, I think you're ok with the AQ. It was just the first (easiest) thing to suggest for you to try.
    Per @tonyb, I agree there's an issue with the "handshake", I believe it can have something to do with the HDMI circuit board in the AVR?
