Speakers with Ribbon Tweeters
hochpt21
hochpt21 Posts: 5,423
After hearing the GoldenEar Triton 2's a couple of times and really enjoying them, I have become very interested in possibly finding a pair of similar speakers for my main listening area. Open, airy, detail...that's what I'm looking for.
I know there are different iterations of ribbon tweeters, and I wonder if any of you guys have some advice/opinions on the matter.
I would be looking somewhat at the lower end in the $1,500 used range.
I have a feeling that Maggies would really give me the sound I'm looking for, but they will not work in my space.
Here are a few that I have researched online so far. The GoldenEar's are the only ones I have actually heard...
GoldenEar Triton 2
Philharmonic Slims Tower
Martin Logan Motion 40
Thanks for the thoughts everyone.
Paul
    mhardy6647 Posts: 35,027
    edited June 2017
    I can't help at all :blush: but -- FWIW -- I generally like the sound of ribbon and planar tweeters The difference between the two is not quite semantic; there's typically a significant affordability gap between run-of-the mill planar drivers and "true" ribbons! ;)
    http://www.magnepan.com/magneplanar_technology
    (again) FWIW, I am actually confused by Magnepan's site as to whether some or all of their modern loudspeakers use "true" ribbons for tweeter panels? Y'all probably know better than I. Historically, the Magneplanars used what the current website refers to as "quasi-ribbons"... but I am way more familiar with the Magnepan panels of 20 to 40 :p years ago than with their current offerings!
    In the interest of disclosure: there are some who opine that the beguiling "there-ness" of ribbons and planar tweeters is due to very high levels of certain flavors of distortion. I am not endorsing this opinion :) but I do feel duty bound to report it :blush:
    http://www.zaphaudio.com/nondomes/
    PS -- no interest in electrostatics? ;)
  • hochpt21
    I wouldn't be opposed to them at some point, but with my current setup, I'm looking for more of a moderate sized slim-"ish" tower.
    EndersShadow Posts: 17,704
    Didn't @marvda1 or one of you TX boys have a set of those and post a review somewhere here about them?
    Yeah I saw a post from @marvda1 with a link to a stereomojo review and then @erniejade bought a set, but not sure if he did a review.... and since his room is like a audio version of a horror movie they didnt work well IIRC....
  • marvda1
    marvda1 Posts: 4,950
    mmmicrotwo's were $40k
    http://www.stereomojo.com/Evolution Acoustics MMMiniTwo Speaker Review/EvolutionAcousticsMMMiniTwoSpeakerReview.htm
    i know where you can get a new pair of mmmicroOne for $2800 pr
    Puritan PSM156
  • marvda1
    i love dome tweeters and find that the only way i like ribbon or planar tweeters is if they are used as super tweeters in conjunction with dome tweeters.
    Puritan PSM156
  • polkfarmboy
    polkfarmboy Posts: 5,703
    Anthony Gallo's tweeters mop the floor with Martin Logan folded motions. Cl2 is my favorite bookie of all time for the money, even if they cost 2 g I would love em.
  • erniejade
    erniejade Posts: 6,321
    LOL yep either they didn't match my room well or mine could have possibly had something wrong with them. In my room the lsi9 sounded much better HOWEVER, I really think something was wrong with them. The seller did tell me he didn't think they had enough dynamics to them but, that 1000000)% contradicts what others have said about them so this leads me to believe, mine had issues to begin with.
    Agree on a horror movie especially with the amount of stuff I have move through this room in the past couple of years. The Kef LS50 Wireless have overcome this but, it could be due to the DSP just working well to compensate the horror room.
    tonyb Posts: 33,072
    Personal preferences.....I like ribbons too, more so than domes. Like domes though, integration is key also with ribbons, they can sound just as fatiguing as some domes do when not done right.
  • polkfarmboy
    tonyb wrote: »
    Exactly Tony, with the gallows I find you get the dispersion pattern of a dome with the transparency of a ribbon.
  • hochpt21
    edited June 2017
    I'll be using the Dared pre and Krell power. I'd like a full-ish range of sound without using a sub which I know is tough on my budget.
    edited June 2017
    ... and then again, some of us are -- just -- horn-y.
  • marvda1
    it's not that i think ribbons sound harsh, they just don't sound natural to me.
    Puritan PSM156
  • pkquat
    pkquat Posts: 748
    I will toss out Newform Research to add to the mix. Some may pop up in your price range. I am a fan of the R8XX series because with the 8" Woofer there is decent bass. The series that used the 7" scan peak drivers are also decent, although have heard you want to find the ones that used two if you want them to have some bass. The later series used 6.5" woofers and are bass shy. They are said to have a better blend with the speed of the ribbons. The 15" ribbon is ok for bookshelf speakers once you have the height set. 30" ribbons are preferred, especially if you like to listen while sitting and standing.. The 45" ones supposedly give the best coverage in any position, but a few people have mentioned refection issues with them.
    I have the R830's and think they do fantastic.
  • DaveHo
    DaveHo Posts: 3,583
    Ascend Acoustics. Sierra-2 if you want a bookie or the Tower with RAAL option for a floor stander. Though the tower is over your price new & probably used as well, if you can find them used. The tower with RAAL was supposed to be my next pair of speakers before I picked up the LSiM during a F&F sale. They might still be my next speakers...
  • sgmsmg
    sgmsmg Posts: 556
    marvda1 wrote: »
    Are the ones you speak of the ones for sale in the Portland, Oregon area? I have seen them for sale here for a while. Thought about giving them a try but didn't really think I would appreciate them. I don't really have the critical ear most people her seem to have.
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
    Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
    Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
    Display: Sony XBR65Z9F
    Pre: Anthem AVM90
    Amps: Buckeye NC502
    Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
    Subwoofers: SVS SB16 x 4
    Source: Oppo UDP-205, Apple TV, Amazon Fire
    Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
    Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
    Display: Sony XBR85Z9G
  • hochpt21
    Thanks for all the good info so far. I'm going to look into all options.
  • steveinaz
    steveinaz Posts: 19,545
    The MartinLogan Motion 60XT's are still on my "potential" buy list.
  • jdjohn
    jdjohn Posts: 3,357
    Some older Infinity's have ribbon tweeters...and magneplanar tweeters. I love the Emit tweeters in my RSIIIa's.
    SCompRacer Posts: 9,112
    edited June 2017
    Ribbons! Paul, go see Aaron (ALL212) in Rockford. He has some ribbon speakers for sale. ;)
    txcoastal1 Posts: 13,513
    Hehehe, yes sir
  • K_M
    K_M Posts: 1,632
    This will shed some light on certain aspects.
    http://zaphaudio.com/nondomes/
    Funnily enough - the Zapf Audio link was provided on the first reply to the original post in this thread.
  • WLDock
    WLDock Posts: 3,073
    edited June 2017
    The hard part is really listening to everything out there. There might be some domes that you like better than some ribbons in some iterations. Still, the Philharmonic Slims, the Sierra Tower and Sierra 2 should be listened to even if it costs a little. If you have some bucks on your charge they both have an at home trial period.
    Here is some used stuff not too far from Wisconsin.
    Anthony Gallo Classico 4: https://chicago.craigslist.org/nwc/ele/6160519125.html
    Carver Amazing AL-III: https://grandrapids.craigslist.org/ele/6132225924.html
    Coincident Victory - http://www.usaudiomart.com/details/649298335-coincident-victory/
    Here are some non-ribbon units in the area that might be worth a listen;
    (I WOULD LOVE TO LISTEN TO THESE!)
    Coincident Technology Super Eclipse - https://madison.craigslist.org/ele/6129306707.html
    Soundfield Audio Monitor 1 (SAM1) -
    (INTERESTING MONITOR WITH THE KEF DRIVER AND ACTIVE LOW END)https://chicago.craigslist.org/chc/ele/6164646071.html
    Some used stuff NOT in the area:
    Aurum Cantus M-103SE - http://www.usaudiomart.com/details/649282965-melody-m103se/
    Salk Archos - http://www.usaudiomart.com/details/649352237-salk-archos-open-baffle-speakers/
    DALI Mentor 6 - http://www.usaudiomart.com/details/649350015-dali-mentor-6-floor-standing-speakers-in-black-ash/
    If you have any DIY skills and desires there are several ribbon kits around. Myself, it looks as if my 2 ch room is not going to happen. So, I'm morphing my system into a dual HT/Music system. Looking at preamps and DAC/streamers now and plan to make some large 3-way WMTMW towers and center later on. The smaller version of them, The Speaker Design Works Jim Holts MiniStatement project might be cool for you?
    http://speakerdesignworks.com/
    https://meniscusaudio.com/product/mini-statements-pair/
    Here are some cool finished projects by some with skills:
    http://i895.photobucket.com/albums/ac158/KnightsOfNi/Speaker Build/IMG_0895.jpg
    http://forums.audioholics.com/forums/attachments/pict0516-jpg.12522/
    http://techtalk.parts-express.com/filedata/fetch?id=1175742
    http://www.htguide.com/forum/attachment.php?attachmentid=19702&stc=1
    http://i196.photobucket.com/albums/aa220/tasknight/Speaker and sub/DSC05156.jpg
    http://www.htguide.com/forum/attachment.php?attachmentid=13338&stc=1&d=1218817137
    Also, there are several cool design from designer Paul Kittinger has worked with Philharmonic Audio and Salk Sound!
    http://www.quarter-wave.com/index.html
    Cavatina ML TL Uaing a Fountek NeoCD1.0 Ribbon Tweeter, ScanSpeak 10F Midrange, and Usher 8945A Woofer - http://www.quarter-wave.com/Gallery/Cavatina.jpg
    The Marcato Speaker
    A Pair of Usher 8945Ps in a 2-way MTM ML TL with a BG Neo3PDR Planar Tweeter
    http://www.quarter-wave.com/Gallery/Marcato.jpg
    Crossover built into the base
    http://www.quarter-wave.com/Gallery/Installedxover.jpg
    The TuLines Speaker
    A Pair of Dayton Loudspeaker RS180 Woofers, in separate ML TL's, with a Dayton RS52 midrange and a Fountek NeoCD3.0 Ribbon Tweeter
    http://www.quarter-wave.com/Gallery/TuLinesFront2.jpg
    http://www.quarter-wave.com/Gallery/TuLinesXover.jpg
    Cantilena
    https://static1.squarespace.com/static/53beb4d5e4b0a307ea878304/53c1f68de4b0d5e06ac3cbc7/53cadc99e4b01d0b9ff000c8/1406776426182/Carnelian.JPG?format=750w
    .....and of course last but not least Rick Craig of Selah Audio (Just met him this year at AXPONA) has several ribbon designs for DIY or made to order: http://www.selahaudio.com/
    Walt
  • hochpt21
    Wow, Walt @WLDock Thank you for the encompassing reply!
    I have seen a few of those listings, but sure will dig through the info you have provided.
    Thanks again.
  • dromunds
    dromunds Posts: 10,126
    WLDock, that is one cool reply!
  • WLDock
    WLDock Posts: 3,073
    Yeah, I'm in the same boat as Paul... wanting some speakers with ribbons. So, I've been looking and listening to what I can.
  • hochpt21
    Actually, something like the Martin Logan ESL's might work in my space.
    Having never owned electrostats. Is there anything a buyer would need to be concerned about?
    Do those panels go bad? Are they finicky? Pets/kids and issue?
  • polkfarmboy
    Panels are great , crappy gear is what puts people off them. Your good in that department so just be sure to slide them out from the wall and best to have 4 walls to get the best out of them but they sound awesome regardless.
    I have a pair of Theo's I am selling I purchased from a martin Logan forum member that I would let go for $2300. I would advise you to spend another 4 to 5 grand on top of that if you want larger panels if you have a really big listening room.
    You cannot smoke around the panels and you need to get out the vac and suck em off every two weeks. You can't have a 20000 gallon fish tank evaporating water next to them. From flipping I have had some speakers come in that look great but the panels had lost a lot of detail and that's just from neglect and low maintenance. If you dont know you would not notice but I can tell right away as the volume has this slightly muted characteristic.
    If you have tube equipment then its audio crack for the ears as the combination from tubes and panels sounds better than anything I hàve ever heard.
  • WLDock
    WLDock Posts: 3,073
    We never forget the first time....
    I will never forget in my 20's the first time I listened to top ML's powered by tube monoblocks playing vinyl! It was like the musicians were in the room when I closed my eyes.
