Polk Hampden Speakers Will Not Play Sound
I have had these speakers for about a year and they just recently stopped producing sound. I mostly run through bluetooth, but the aux and usb options do not work either. Is their any way to fix them or am I SOL.
    nooshinjohn Posts: 25,879
    edited June 2017
    Best advice I have would be to contact Polk CS department on Monday.
    Polk Audio Technical and Warranty Support
    For assistance or replacement of Polk Audio products
    Call 1-800-377-7655 Option 1 or
    Email technical support: polkcs@polkaudio.com
  • hstorrer
    hstorrer Posts: 2
    Yep. I figured as much, I was just hoping some one here would have some kind of electronic seance ritual to get me through the weekend.... :)
  • gls
    gls Posts: 1
    Did you have any resolution to this problem. I’ve had the Bluetooth go totally out.
