Is there such a thing as too much black hole five?
Answers
  • analogluvr
    analogluvr Posts: 72
    With mine it just peeled off. It didn't really remove any of the particleboard except for a few Dusty fibres which makes it not really sticky again
  • machone
    machone Posts: 1,562
    I was not able to peel mine away from the board. It separated and left the BH5 base material. :#
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    F1nut Posts: 51,930
    The adhesive on it is extremely strong. I wonder since analogluvr was able to remove his so easily if that had something to do with his results as it needs to be bonded solidly to the foundation to work properly.
  • kevinko
    kevinko Posts: 165
    Is there any prep recommended or needed before installing?
    F1nut Posts: 51,930
    Not that I'm aware of. The trick is you have press it on hard, you just can't slap it on.
  • machone
    ^^^^ This and wipe any dust off with a damp rag before application.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • kevinko
    kevinko Posts: 165
    You could dab the area with a little masking or packing tape to pull off any loose fibers.
  • ptrooper
    ptrooper Posts: 501
    after a year trial I have now removed the 3" wide strips from the sides of the sda srs and put the size recommended by Dark Knight ...much better !
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited November 2017
    You guys will get a laugh at my very obvious mistake. I bought some BH-5 from a C/L and he had many scraps all over the place plus the intact sheet I bought for $12. He did mention that there was no stickum on the loose pieces which were the 3"" wide albeit to long. I said I have Liquid Nails and that stuff sticks to anything thing. Well there was a question posed over on AK and sure enough Jesse noticed my mistake. I put the dark side down w/ the LNs then moved on to the other cabinet and saw my miss doings ,scrapped the beat cabinet clean and then used the new sheet and placed it the correct way. Jesse must of been laughing for hours at my expense. Here's what not to doubct43o6cx9q.jpg
    Viking64 Posts: 7,604
    And this is why we have deja vu, folks. :o
  • trav0810
    trav0810 Posts: 1,056
    I have a piece of this and was considering using it inside my Cornscalas. Where would be the best place to place it?
    The difference between genius and stupidity is; genius has its limits.” -Albert Einstein
    Sony Playstation 3 for CD and Streaming
    Thorens TD320
    Modified Carver C-1
    Carver TFM 42 and 45 Amplifiers
    Polk RTA15TL Speakers w/Decato mods
    White Lightning Moonshine DIY Speaker Cables and Interconnects
  • lightman1
    lightman1 Posts: 10,797
    Over your ears to squelch the laser bright highs...... :DB)
    Kidding. No clue at all, Travis....
    pitdogg2 Posts: 27,208
    Usually its behind the drivers. Is the mid and tweeter both horn driven? I do not know about putting it behind an active bass driver in SDA's and passive radiators we do not put anything down behind that.
  • trav0810
    edited November 2018
    Yep, horn mids and tweets. There is not any kind of dampening materials inside the cabinet at all
    Thorens TD320
    Modified Carver C-1
    audioluvr Posts: 5,982
    lightman1 wrote: »
    ^^^ oooo! Not a bad idea! I've been using feather pillows!
