Is there such a thing as too much black hole five?
I have a pair of SDASRS twos and I got my shipment of black hole five today. I got a lot. I was thinking of doing the whole area behind the mids and tweets from side to side, not just doing strips. Is there a potential downside besides cost or is it a good idea?
Best Answer
Answers
  • motorhead43026motorhead43026 Posts: 3,822
    Too much and you will be wondering, where is the bass.
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
    Other; S60'S, M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
    There are three things that give a man a false sense of courage, a keyboard, alcohol and a firearm.
    Motorhead, 4.12.20
    tonyb said " but even socialists can do a good thing here and there
    the substitution of politics for existence is the supreme betrayal of the subjective otherness of man.
  • F1nutF1nut Posts: 45,620
    This.
    Do not put anymore in than the 3 or 4 inch wide strips behind the mid-drivers.
  • analogluvranalogluvr Posts: 72
    OK thanks. Do you find that it tightens up what bass there is? Because right now I find I have an excess of base.
    How do you generally fasten the stuff up? Can I use PL premium? Can I also use PL premium for the driver magnets?
  • Toolfan66Toolfan66 Posts: 14,658
    I was stupid enough to do the entire cabinet years ago, DON'T DO IT, the strips are perfect...
  • machonemachone Posts: 1,303
    On my 2.3TL's:
    I put a strip of Black Hole behind the four stereo drivers and the same length strip behind the sda drivers. And an additional strip behind each of the three tweeters.
    Should I remove the pieces behind the tweeters?
    Should I reduce the length of the sda strip so that it is only behind the two sda drivers?
    Thanks :|
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • stones89stones89 Posts: 232
    I put mine behind the MW's only on my 2.3tl's. still burning in the new caps so I don't know how much the BH has contributed to the sound.
    Basis 2200 Signature, Vector 4, Transfiguration Proteus, Allnic H3000, Meridian 200/563, CJ ET5, McIntosh 501's, Thiel CS6, 3.6, Polk SDA SRS 2.3tl, MIT EVO, KS/Wywires PC's
    machone wrote: »
    On my 2.3TL's:
    Thanks :|
    You want it behind all the MW's, no benefit behind the tweeters. Won't hurt anything, it was just a waste of material.
    Motorhead, 4.12.20
    So I didn't listen then I filled all four spots behind each mid woofer. When I listened it had sucked all the life out of the sound and there was no bass just as I was told by you folks. So I pulled out what was behind the bottom two on each side and listened again. It was much improved but not as good as it was before. So I pulled The last two pieces though and it was back to sounding glorious. In my humble opinion I don't think it's a benefit to the sound. Even the second time I listened when there was only a little bit left in there it seemed there was less detail and resolution.
    At minimum I would advise experimenting and listening as I did. Find your preference and go with it.
    Everyone else and I mean everyone that has added BH5 found it to improve the sound.
  • hochpt21hochpt21 Posts: 5,351
    analogluvr wrote: »
    I do appreciate the fact that you trial and errored your way through the process, and how you prefer the sound might be different than the next guy.
    __________________________________________________
    Turntable - VPI Scout 1.1/Ortofon 2M Blue
    Amplification - Parks Audio Budgie, Dared SL2000a, McCormack DNA 0.5 Deluxe
    Speakers - GoldenEar Triton 2
    7.1 Home Theater
    Denon AVR-X3300W; Rotel RMB-1066; Polk CS350ls, LS90's, FXi3's, RC60i; SVS PC Ultra; BenQ HT2050; Elite Screens 120"
    Man Cave
    Turntable - Pro-Ject 2.9 Wood/Grado Gold
    Integrated Amplifier - Rogue Audio Cronus Magnum II
    CD: Cambridge Audio
    Speakers - LSiM 703; SDA 2A; Epos Epic 2
    I removed the BH5 from behind the tweeters and cut 5" off each end of the strip behind the sda drivers. So now it is only behind the mid stereo and sda drivers. Turns out this is 42% of the original BH5 area. Not a trivial amount.
    The overall balance is better along with the stronger bass.
    A little bit goes a long way. Live and learn.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • polrbehrpolrbehr Posts: 2,717
    edited May 2017
    @machone, I am not really laughing at your post, I thought it would look neat
    having four "1"s in a row...
    I am finally going to try this mod myself on my 2Bs, now that they're getting relocated it's as good a time as any to take them apart.
  • leftwinger57leftwinger57 Posts: 2,918
    You guys will get a laugh at this one. I also installed BH-5 in my '87 2Bs. I posted the pick over on AK and of course Jesse who also frequents there said Lew what is the white doing in the cabinet. Well here's the story, the dude I bought the sheet from also had already cut on a band saw perfect sizes for me but he said they were very old and had no stick-um left on them and were free. I said I have Liquid Nails and that sh%t holds anything. So cabinet #14di54wwt92q3.jpg
    is done and then I go to the new sheet and I said I put it in **** backwards. I do have pics of the wrong way but I had enough to clean up the first cabinet and all is well w/ the world.. ]
  • gmcmangmcman Posts: 1,611
    @machone ...just curious, when you are experimenting with the BH5, applying or removing, are you leaving your speakers sit in the exact same spot,.or are you moving them?
    Do you lay them flat then stand them back up, or work with them as they stand?
    Reason I ask this, if In fact you do move them, 1/2" difference from where you last placed them can make a big difference in bass response.
    My midrange clarity improved with the BH5, bass didn't suffer any...was cleaner if anything. If I had to put my finger on what happened to the bass with my 2B's, is that it cleaned it up, if it was less "noticeable", I would say it was less muddy so the perceived amount of bass could be less, but it is cleaner and tighter...not boomy.
    gmcman,
    I mark the floor with tape, measure to the wall and eye ball for location.
    When I first added the BH5 I did several mods at the same time (Larry's rings, cabinet sealing) and the bass did become much tighter and an overall improvement. But I have always been in a quest for more deep bass in this room. I have tried different speaker locations and lately I have been adding bass traps. I like the results of the bass traps and plan to add more.
    It was not until this thread that I questioned myself that maybe I applied too much BH5. It seemed worth it to remove the areas that were not directly behind the mid drivers.
    Now that I have listened a few nights I can say that on some recordings the bass could be touch tighter. I am hoping that this can be adjusted without affecting deep bass by moving the speakers a little further away from the wall. I am guessing that this would be no more than 1/2".
    We all know that every room is different and speaker location affects bass. Maybe in my room I need to adjust both the location and BH5.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    [I also marked the floor before tearing into them. Then just for ease of placement and the drilling for Larry's rings I laid them down. Drilling those must be plumb vertical to get the right fit..
    machone wrote: »
    That's also a possibility, if you kept the speakers in the same space, and are now experiencing different bass with the BH5, then perhaps you need to move them closer to the wall, use small increments.
    When I did my speakers I laid them down to remove it but I am fairly certain I had them in the same spot when I put them up. In my experience it takes bass away so it is perceived to be tighter with it in. I just found that it took bass and life out of the speaker which was rather obvious when I put a large amount of the stuff in. I can see how some people might prefer it with just a very little bit of the stuff but I would rather work on tightening the bass with placement and other ways as opposed to removing it with the black hole five.
    I forgot to mention that installing the bh-5 was one of the mods that made a huge difference in sound. Yes the 194s are better than the Sliverdomes and of course up grading x-overs does it's thing but I was shocked at the difference between the hollowness of the cabinets before installing the bh-5 that it was so different I had to really adjust to the new sound which became very clear was the way to go. If using bh-5 why then do the Dynamatt thing also ? Kinda late asking now
  • ptrooperptrooper Posts: 458
    I to had to readjust to the new sound and it was definitely for the better as everything settled in.
    I also remembered reading through DK's posts and how he said he would like to have tried a little more installed......i not only installed 3" strips behind the MW's but also to each side of the cabinets . I definitely do not have a problem with lost bass or midrange!
  • pitdogg2pitdogg2 Posts: 18,270
    edited June 2017
    If you have them spiked and put tape down around the spikes it is real easy to get them exactly in the same spot. If you have them spiked on carpet it is even easier to put the back in the exact same spot.
    edited June 2017
    analogluvr wrote: »
    BH5's primary function is to clean up the midrange, which it excells at and in turn it cleans up a bit of boom, which you may think is bass. I and those that have heard my rig can tell you that I have bass in spades or as one member put it, like swimming in a pool of bass.
  • kevinkokevinko Posts: 157
    If using bh-5 why then do the Dynamat thing also ?
    I'd like to know too. What are the sonic benefits of installing both?
  • ken brydsonken brydson Posts: 8,117
    Dynamat stops the basket ringing.
    gmcman wrote: »
    machone wrote: »
    Recently I moved them closer to the wall and the image suffered. Now I am experiencing better SQ with less BH5.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    edited June 2017
    machone wrote: »
    gmcman wrote: »
    machone wrote: »
    When I layed mine down flat recently to finish some cabinet sealing, along with a few woofer gasket changes, I noticed some muddy midrange. I thought it could be the new gaskets and not fully coupling the woofers to the cabinet....since that was the only thing that I changed with significant value.
    I triple checked the placement and measured from the wall, had 7 3/4" from wall, top to bottom. Then I eyeballed the cabinets from left to right and the left was clearly 1" in front.....odd.
    So what takes precedence of you can't have both......equal distance from front wall, or face of speaker on same plane to listening position.
    I put the front of the speakers on the same plane and that took care of the muddy midrange/ bass, made quite a difference. I had them that way before, but never realized my front wall was not straight...at least this bad.
    Get next to one of the speakers, and look down the back of the cabinet, move your head with one eye open until it becomes one vertical line, then see if the other speaker disappears at the same point.
    Here's mine when it was way off, the left speaker is actually 1" CLOSER to the front wall, however it's about 5/8" in front of the right speaker if you put a straight edge across both speakers.
    So just double check the placement. When mine were equal distance to my wavy front wall, the mid bass was muddy and almost sounded like it was resonating.
  • DrahthaarDrahthaar Posts: 48
    Machone,
    machone wrote: »
    I also have it installed behind the tweeters on my 2.3tl's. How hard was it to get off, did it just peel off, also did it do any damage to the particle board.
Howdy, Stranger!
