Average volume for listening
What's everyone's average db level for listening. I find that I really rarely "crank it up" and if I do it's only for a short passage in a song. It sounds great but I don't find it as pleasing to listen at 95-100db as say 75db.
Onkyo TX NR 5008 modified by The Upgrade Company
Oppo BDP 93 modified by The Upgrade Company
Arcam CD37
Monitor Audio Gold GS 60
Revolver Audio Music 5 towers.(surround)
Vandersteen V2W
  • afterburnt
    afterburnt Posts: 7,892
    Isn't 100 supposed to be the pain threshold? I rarely go above 80 but mostly much lower. I like my ears, given the choice I would probably rather stare into the sun.
  • mpitogo
    mpitogo Posts: 520
    On an Audyssey calibrated system typically -20 to -10 dB.
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • BlueFox
    BlueFox Posts: 15,250
    Depending on the music, and day of the week, between the high 60s, and into the 70s. For example, currently listening to a string quartet, and it is in the high 60s. Listening to rock on Friday and Saturday night will get into the 80s, with, maybe, a brief period in the 90s.
  • jayman_1975
    jayman_1975 Posts: 672
    edited May 2017
    Yeah it probably would be. I'll measure tomorrow where I mostly listen and at what db level I would count as cranking it up. I think I hit 90db once when I was trying out my new amp but only kept it there for a maybe 10 or so seconds. I suppose I have never seen 100db as it wasn't too comfortable at 90 even.
    Arcam CD37
    Vandersteen V2W
  • jayman_1975
    mpitogo wrote: »
    mpitogo wrote: »
    Mine is Audessy calibrated and I usually listen at -20 to -30 even depending on the music. . If I'm feeling particularly frisky I might hit -10 but not often
    Arcam CD37
    Vandersteen V2W
  • kharp1
    kharp1 Posts: 3,453
    I do't have the exact figures handy, Senator, but rest assured it's somewhere between loud and louder.
    F1nut Posts: 51,962
    edited May 2017
    One thing you guys need to specify is which scale on the SPL meter you are using.
    If you're hitting 90 to 100 on the "C" scale and it doesn't sound good you need better gear. With better gear you don't notice how loud or even louder than 100dB is.
  • Nightfall
    Nightfall Posts: 10,083
    I don't have a dB meter but I'd guess I average high 70's low 80's.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Joey_V
    Joey_V Posts: 8,603
    70s
  • dannylightning
    dannylightning Posts: 233
    edited May 2017
    my meter shows in the 60-70's most of the time.. when i feel like cranking it up 80ish db seems good, its loud but not really loud.
    those of you talking about odyssey and negative db numbers. if you were listening at -10db you would not be able to hear the music. its showing you a adjustment number not the db you are hearing the music at.
    human berating measure around 10db, a human talking 60db, a alarm clock 80db, chain saw 110db, if its too loud your too old.... lol.
    Cambridge Azur 651A
    Polk LSi M703
    Sonos Connect
  • mpitogo
    mpitogo Posts: 520
    Playing classical music Tchiskovsky Pathetic at times it hits 85dB slow response A weighted.
  • machone
    machone Posts: 1,564
    I set my A weighted meter to hold peaks when I listen.
    80-85 is the average peek with 90 on the high side.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • codycatalist
    codycatalist Posts: 2,661
    Don't have a meter but I guess it would depend on if I have had some big boy drinks or not and if it is the weekend. If those two are met then ear bleeding will commence.
  • BlueFox
    That is the truth. While I wasn't using my SPL meter at the time, when I blew up my S5 MKI speakers I was literally being pounded by the sound. Yet, I was thinking how can this sound so good, but be so loud. LOL
    Prior nights before that I consistently measured in the 100s with peaks over 110db. Never again. That was an expensive lesson. :)
  • mrbiron
    mrbiron Posts: 5,721
    When the family is home......Moana plays at a 50-60
    When the family is NOT home, i crank Moana up to 80-90.
    You're welcome!
  • halo
    halo Posts: 5,618
    SPL meter, C weighted, shows that I'm in the high 60 dB to mid 70 dB range most of the time.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited May 2017
    "C" weighting, fast response SPL meter.
    I measured avg 85 dB for *critical* listening.
    Scare the neighbors loud with Sabbath was measured at 98 dB peaks.
    Measured distance from speakers with the SPL meter - 12 ft.
    Clean, pure, and totally awesome.
  • voltz
    voltz Posts: 5,384
    I use a meter at home most of the time and try for around 80-85 also.
    it is Funny when you leave the room and now you notice how loud it is :p as it didn't sound as loud when your in the room in the sweet spot!
    mhardy6647 Posts: 35,208
    mrbiron wrote: »
    You're welcome!
    Signature-worthy material, right there, folks.
  • Mikey081057
    Mikey081057 Posts: 7,127
    75-80 dBC
    Garage | Polk Monitor 5B's
  • gce
    gce Posts: 2,158
    Mine goes to 11.
    Anaheim Hills CA,
  • drumminman
    drumminman Posts: 3,396
    Totally agree. I can have it loud and not realize it's making it difficult to converse with the person next to me because it's so clean.
  • jayman_1975
    I was listening tonight on my second rig at 85db and it was clean and not stressed. Any more and I feel it would start to fall apart. Mind you this is with a cheaper Yamaha integrated amp providing the muscle. 80wpc. On my main rig I have stand alone 2 channel amp at 300wpc and can hit 105db and it's clean and crisp. Louder than I would listen to for very long but still tight as a whip.
    Arcam CD37
    Vandersteen V2W
  • Thorton
    Thorton Posts: 1,324
    DSkip wrote: »
    If the bass doesn't adjust my hearts rhythm, it isn't loud enough.
    Sig. material. Love it.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • Thorton
    Usually 80 - 90+ db depending on my mood and the content. 60 db'ish is background music.
    DAC: Bricasti M1SE
  • Moose68Bash
    Moose68Bash Posts: 3,843
    When my wife is listening, no greater than 65 dB.
    When I'm alone, it depends on the music. Symphonic music requires a higher level because of the dynamic range. Solo cello is great at a lower level -- say 70 dB.
    Pavarotti: As loud as I can stand it, but no greater than 85 dB, which is where I believe damage to the hearing begins.
    I don't listen to much rock music, but when I do, I say Skip hit the nail on the head.
  • Willow
    Willow Posts: 11,251
    mrbiron wrote: »
    You're welcome!
    So you really like to let system shine, shine ,shine when no one is around?! That's cool.
