Powering a pre amp....
kevhed72
kevhed72 Posts: 5,157
edited May 2017 in 2 Channel Audio
Curious how many of you run your pre through a power conditioner... as well as, what type of power cord do you use... in terms of brand and awg. I recently upgraded from a stock power cord, and plugged directly into the outlet, only to experience the dreaded ground loop hum...
  • doctor r
    doctor r Posts: 837
    Presently using Audience PowerChord e cables and Audience conditioner. Interesting that you have a hum appear just from changing away from a stock cable. Does it disappear when you substitute the stock cord back into the system?
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    New cable have a ground pin that wasn't there before or is it a shorter cable that's making a quicker path to ground than the original configuration?
  • Mikey081057
    Mikey081057 Posts: 7,127
    are you routing cable in proximity or crossing over a signal cable?
    Garage | Polk Monitor 5B's
    He's not using the power conditioner with the new cord. Chances are the ground loop hum was always there, but once he moved away from it and went directly into the outlet.....hum.
    Plug it back into the conditioner.....or try a cheater plug on it for 2 bucks.
  • kevhed72
    I have a coupe of MIT network boxes on ICs which are probably too close to an outlet and a power cord. It's my understanding it's better not to cross ICs and power cords at all....or if you had to, don't run them parallel right next to each other.....I forget.
    More than likely, too many grounds in one spot. Try separating to another outlet if you can or lift the ground with a cheater plug. Also, it may benefit some to change out the wall outlet if it's still that old construction grade stuff.
    Another cheap way is to run a wire from a screw on the pre to another piece you know has no hum and grounded well. Hum is rarely due to the cable itself, unless it's of very cheap quality.
  • acmf74
    acmf74 Posts: 937
    I run my Cary Pre and Jolida CDP through a APC power conditioner using Pangea AC 14SE Power Cables. Dead quiet.
  • Mikey081057
    kevhed72 wrote: »
    Don't cross the streams....
  • kevhed72
    kevhed72 wrote: »
    How close is too close....
    pitdogg2 Posts: 27,246
    if you must have them close cross them at 90 degrees
