Suped-Up RTi-A7s
mdale
mdale Posts: 38
Hi. What are your thoughts/suggestions about upgrading RTi-A7s? Could replacing the crossover circuits be a good move? They look great, and I have the matching center and surrounds. I surely won't get my money back on a sell or trade. Retrofitting them could be cost-effective and yield good results. Thank you for your responses.
Yamaha RX-V667 Receiver, Emotiva XPA200 Amp, Polk RTi-A7 Mains, Polk CSi-A6 Center, Polk FXi-A6 Surrounds, SVS SB2000 Subwoofers, Furman ELITE-15PFi Power Conditioner
  • Legender
    Legender Posts: 478
    Search is your friend... this should help you get started.
    http://forum.polkaudio.com/discussion/139063/review-of-the-modded-by-vr3-rti-a7
    Good luck!
    Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
    Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
    Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
    2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
    Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
    Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra
  • mdale
    mdale Posts: 38
    Hi Legender. Thank you for the link! A while ago, I read about VR3 mods, saw the website, and read the testimonials; but they're not inexpensive. Does this forum think it a wise approach?
    F1nut Posts: 51,959
    edited May 2017
    The improvements from my crossover upgrades were not subtle.
    RTiA7's
    CSiA6
  • mdale
    mdale Posts: 38
    F1Nut: These look fantastic. Did you build these yourself? Would you do it again? And if you have the matching surrounds, did you upgrade them as well?
    F1nut Posts: 51,959
    Thank you.
    Yes.
    For myself, yes.
    Yes and yes.
  • mdale
    mdale Posts: 38
    Inspirational! Thanks for sharing. I'm now on a mission to find a parts list...
  • mdale
    mdale Posts: 38
    By the way, did you keep the original drivers?
    F1nut Posts: 51,959
    mdale wrote: »
    Yes, there's no reason to replace them.
  • gp4jesus
    gp4jesus Posts: 2,019
    edited May 2017
    Listen to this or any other person that says or does the above. Even a simple but cheap internal rewire Is well worth it.
    You could bi-amp them AND do a mid/tweet XO upgrade or tri-amp them.
    Tony
    *all connected w/Premiere ICs
  • mdale
    mdale Posts: 38
    Hi Tony. Is it possible to simply replace the original discreet components with the same components of the same value but of higher quality?
  • gp4jesus
    edited May 2017
    YES! See Jesse's (F1) "Fun w/RTi A series speakers or crossovers." My personal favorite XO component upgrade application.
    Get some Cardas Quad Eutectic solder before you start. You won't regret it.
    Post edited by gp4jesus on
  • mdale
    mdale Posts: 38
    Tony, thank you for the helpful advice. I'm looking forward into delving into this project. I will look into the website as you suggest. Thanks, again!
  • gp4jesus
    Here's a link to Jesse's A7 & A6 XO awesome upgrade thread.
    http://forum.polkaudio.com/discussion/159998/rtia7-and-csia6-crossover-upgrades-a-slightly-different-approach/www.crgproducts.com
    He posted pics above from that thread. Some may prefer different make and/or model components but none would argue w/the attention to detail!
    Tony
    F1nut Posts: 51,959
    Thank you Tony. I dare say your tri-amp work took it to another level or three.
