Cheap way to play flac, wav, mp3 without a computer
  • Emlyn
    Emlyn Posts: 4,868
    What type of cell phone has an 18 inch screen on it?
  • lightman1
    lightman1 Posts: 10,797
    edited May 2017
    I have no idea what y'all are talking about.
    Seems I need a $12k DAC to listen to a set of headphones that cost $200.
    Or.... I can stream music from one 67,236 services offered online, as long as I purchase the proper driver to play the music I have purchsed previously. Then after that, I should consult the CHIP gurus to tell me my stock DAC/streamer won't work with this version of LAN based NAS because Apple hates Andriod and vis-a-vis.......
    You all suck the green version of donkey testes.
  • pkquat
    pkquat Posts: 748
    erniejade wrote: »
    I found a Lenovo T430S I5 with 8 gig of ram for 100$, hifimediy sabre usb dac es9023 for $42 ( it gets great reviews at this price) and a Toshiba usb 2 tb drive for $79$ Just need to load up Jriver and he should be good for under $250. Solid for a garage system on a receiver I think
    Sounds awesome. Just an FYI, I have often seen 4TB drives from the big 3 for about ~$100. Sometimes its $10 more for the smaller portable version, sometimes the same. If you go with a portable one, I recommend a powered usb hub to reduce the power load on the PC if its always on.
