ocd - background image; can we get something more filling please?
msg
msg Posts: 10,458
This sparse LSiM based background is messing me up.
I've had three seizures since it's changed, and lost my job because of it. The neighborhood feral tabby wants nothing to do with me anymore, either, and I even tried rubbing down with canned salmon.
Can we get a better fitting background image back again, please, something less vacuous and floaty? Something grounding so I can be back out in amongst the general citizenry without people staring at me, muttering incessantly to myself?
    mhardy6647 Posts: 35,193
    If we could just find a reliable source of black paint, you could mask off the center of your screen and spray paint the sidebars.
    Just brainstorming here -- no wrong answers, y'know?
    msg Posts: 10,458
    That's a fantastic idea, Mark. Indeed. Too bad about the black paint, howeverrr...
    Inspires me to skin some midnight mahogany slivers off a set of 705s with a power planer to Gorilla Glue on for a color change, since the MVC never quite worked in my space.
    msg Posts: 10,458
    Side note: does anyone know how to work Gorilla Glue properly? Is it the addition of water that stops it from never-ending expansion, like that canned foam?
    F1nut Posts: 51,933
    Horrible, horrible glue. It cures via moisture, so it foams up creating air bubbles weakening the adhesive quality, which is exactly the opposite of what you want. Throw it away and buy some real glue such as Titebond.
    edited May 2017
    I was quite taken aback the first time I used it [Gorilla Glue]. It may have also been the last time I used it, come to think of it.
    Hipster that I am, I think I still prefer glue made from horses' hooves. The terroir , of course, is very important, just as in the production of a fine wine.
    msg Posts: 10,458
    Good to hear.
    Yeah, I tested it once and never really used it. It was weird stuff.
    I'll check out that Titebond stuff.
    ha, yes, exactly my experience as well. like a wtf is happening moment.
    making glue out of horses and gorillas.
    terroir determines efficacy [horse whinny]
  • Gatecrasher
    Gatecrasher Posts: 1,538
    Which Gorilla glue is bad? All of them? They make like ten different kinds including Super Glue.
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    Forget Gorilla Glue.
    Don't mess around, man up, and use JB Weld.
    If it isn't moving, JB Weld it.
    msg Posts: 10,458
    JB Weld also makes for a great pranking adhesive.
    Especially funny with stuff like keyholes, weighting one shoe, accelerators, dentures, etc.
    F1nut Posts: 51,933
    Other than the original Gorilla glue (the horrible one), the rest of their products are the same as everything else that was available before theirs.
    F1nut Posts: 51,933
    I have been informed that the current background is in support of the LSiM sale and we should have the darker one back next week.
    msg Posts: 10,458
    edited May 2017
    Figured as much, yeah, thanks Jesse.
    FWIW, when it comes to cyanoacrylate adhesives, I am a firm believer in using the products that the R/C aircraft hobbyists use. That stuff has to be strong; even the little trainer planes are subject to some pretty serious stresses in flight, and if the glue's not up to it, disaster may strike.
    I use these (again FWIW) for many applications and with good results.
    http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXK282&P=ML
    http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXK286&P=ML
    http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXK290&P=7
    The thicker formulations cure more slowly, but will fill gaps and work in situations where the classic thin CA adhesives just don't get the job done.
    (just my non-expert, end-user opinions, of course)
    msg Posts: 10,458
    Oh, I think I'm just now for the first time seeing the forum background the way it's intended to look for the LSiM sale. Actually pretty cool. I'm okay now. This is acceptable. Carry on.
    msg Posts: 10,458
    Except now it's like looking into two mirrors facing each other...
    msg Posts: 10,458
    Somebody get me off this ride, havin' a bad trip
    Infinity. It's not for the faint of heart.
    On topic :) One does note that the background behind the loudspeakers in the sidebars is a very light blue, not pure dazzling white.
    umm -- who needs drugs, man?
    msg Posts: 10,458
    insightful like lol
    Mark - looks offwhite/gray to me, but what do I know. I can't see my bbcode color working, so I might be forum colorblind.
    could be -- this display's not calibrated, and I am not sure I can reliable distinguish light blue from grey, myself.
    gudnoyez Posts: 8,172
    It's the double
    msg wrote: »
    It's the double Whammy subliminal message I'm sure you gave in so how many pair of LSIM's have you bought?
    msg Posts: 10,458
    Hehe, doesn't everyone's bathroom need a pair of 707s?
  • Malbec
    Malbec Posts: 558
    Gorilla Glue does serve one purpose.
    txcoastal1 Posts: 13,518
    Completely agree
    It's intolerable while on your PC or pads
    msg Posts: 10,458
    DSkip wrote: »
    Can we get this background changed to something darker now? I think the LSIM look awesome but since getting hit with the change I cannot stand being on the forum on a PC.
    Maybe it's time for Leonard Cohen's swan song, then?
  • [Deleted User]
    [Deleted User] Posts: 10,716
    I'm not seeing a problem.
    What does your page see on your PC?
  • [Deleted User]
    the new speaks.
    the new speaks.
    Is your screen solid white like the other LSiM pics posted
