Crossovers upgraded/refreshed or new integrated?
Not sure which I should do first.
I will be having some expendable funds coming my way in the form of $500ish. Not sure if I should get a new integrated (currently have Yamaha Av34) or if I should get my crossovers completely redone with new binding posts on my SDA 2Bs.
Help me decide.
Eventually both will be accomplished but more than likely a year or so apart.
    msg Posts: 10,550
    edited May 2017
    How do you like your current integrated with the speakers as they are?
    If you like it, I say go crossovers first, settle into those before you make a decision on direction to head for your next front end?
    Which other integrated amps would you be considering, I suppose would be the next question.
  • codycatalist
    codycatalist Posts: 2,661
    I do like how it sounds currently, if I had to nit pick I would want more stereo separation and a warmer sound. I haven't really looked around much before as window shopping gets me in trouble. I haven't heard a ton but I do like the marantz sound and looks, old and vintage.
    I know I need to look around just to even gain a good perspective of what I am looking for but I don't care about the bells and whistles. If it sounds good, looks decent, pairs good with my SDAs and is common ground I'll be happy.
    I will probably end up going used for the integrated so that is not out of the question.
  • voltz
    voltz Posts: 5,384
    A say maybe a crossover upgrade and change the binding post to handle speakons for the inter connect cable and maybe add a Dreadnaught.
  • codycatalist
    voltz wrote: »
    voltz wrote: »
    voltz wrote: »
    add a Dreadnaught.
    See that's 3 money signs...Wife will only allow 2 money signs. The 2 former options are more than likely the route I'll take and add a dreadnaught in the future. Beyond the old caps on the XO I feel the weakest link in the chain comes back to the integrated. That's what makes me question it a bit.
