Polk RT8 Speakers not working
Hi there,
I bought A pair of RT 8, Floor Standers in 1997. Each has got a tweeter and a woofer. One of my woofer doesn,t work. I checked for the problem and found out that the aluminium sheet which holds the coil to the cone is broken. ( don,t know the name)
What can I do. should I replace the whole speaker or should I get the part and replace it. In both cases I need to know where to get the parts and how much it will cost.
I live in Brunei Darussalam which is in the island of Borneo. There are no agents here therefore i can't find any help here.
Thank you very much. Please help
Regards
Khanan
Regards
Khanan
Post edited by khananmv on
khanan,
Welcome...
Look at the top of the page in the yellow band. Click on the part that reads, "Service and Parts", send an e-mail explaining the problem with your 8's, and you are on your way.
And do be sure to mention you are a Club Member.More later,
Tour...
Vox Copuli
