Decisions, decisions,decisions??????
soundfreak1
in Electronics
Parasound A23 or parasound HCA1500A. I know the HCA series well but no experience with the halo series. Big wattage different but what abour the sound quality. Opinions requested.
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
@DSkip has a lightly used A23 he might be willing to part with. Any of the HCA stuff pobably needs to be recapped at a minumum. The A23's a nice can fill a small to mid size room with Parasound.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
I have owned both the last year. The HCA digs deeper and is a bit warmer. Can't go wrong with either one. I still have the 1500 and use it everyday.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
Idolizing a politician is like believing the stripper REALLY likes you. -
Depends on your preferences really. I would prefer the HCA series over the Halo for it's added warmth. Halo series to me is more detailed, neutral sounding.HT SYSTEM-
lsi 9's -
My system is not "warm" very detailed so maybe the halo might be more to my liking. But the 1500 does do a fine job on the bass (350htz&down). But more detail is appealingMain Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
^^Then go for the A21.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
@soundfreak1 I had an A23 for a while. It's a fantastic amp which will most definitely not lead you astray. I agreed with the comments on it being detailed, but I found it warmed up nicely paired with a Marantz component earlier in the chain. I've never listened to one of the HCA amps, so I can't offer any advice on that end.
Not sure what you're driving with it, but it made my RTIA3's sing. Big time. -
soundfreak1 wrote: »My system is not "warm" very detailed so maybe the halo might be more to my liking. But the 1500 does do a fine job on the bass (350htz&down). But more detail is appealing
Too much of the same type of sound can be a bad thing. -
My HCA-1500A is still chugging along like a champ.
My father is looking for a new amp and we listened to an A23 and the Rotel RB1582 MKII.
We both liked the Rotel better. Warmer and better controlled soundstage. This was also hooked to an Oppo 105 that many consider bright and analytical.
As others have said, match your equipment to avoid too much of one thing. -
I've desided to just keep the 1500 until something further up the ladder comes along.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
The Halo series is basically a rebadging of the HCA series. I better tell my 13yr old HCA amp it needs new capacitors....LOLSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I'm just using it for biamping my bass at 350 htz and down.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Used to have an recaped hca1200 driving RTA12C''S and it did a very fine job, then I found a krell amp and it was a whole new ball game.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
