Decisions, decisions,decisions??????
Parasound A23 or parasound HCA1500A. I know the HCA series well but no experience with the halo series. Big wattage different but what abour the sound quality. Opinions requested.
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
  • Mikey081057
    Mikey081057 Posts: 7,127
    @DSkip has a lightly used A23 he might be willing to part with. Any of the HCA stuff pobably needs to be recapped at a minumum. The A23's a nice can fill a small to mid size room with Parasound.
    Garage | Polk Monitor 5B's
  • motorhead43026
    motorhead43026 Posts: 4,031
    I have owned both the last year. The HCA digs deeper and is a bit warmer. Can't go wrong with either one. I still have the 1500 and use it everyday.
    Depends on your preferences really. I would prefer the HCA series over the Halo for it's added warmth. Halo series to me is more detailed, neutral sounding.
  • soundfreak1
    soundfreak1 Posts: 3,414
    My system is not "warm" very detailed so maybe the halo might be more to my liking. But the 1500 does do a fine job on the bass (350htz&down). But more detail is appealing
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • motorhead43026
    ^^Then go for the A21.
  • andrew82
    andrew82 Posts: 144
    @soundfreak1 I had an A23 for a while. It's a fantastic amp which will most definitely not lead you astray. I agreed with the comments on it being detailed, but I found it warmed up nicely paired with a Marantz component earlier in the chain. I've never listened to one of the HCA amps, so I can't offer any advice on that end.
    Not sure what you're driving with it, but it made my RTIA3's sing. Big time.
  • kharp1
    kharp1 Posts: 3,453
    Too much of the same type of sound can be a bad thing.
  • Upstatemax
    Upstatemax Posts: 2,816
    My HCA-1500A is still chugging along like a champ.
    My father is looking for a new amp and we listened to an A23 and the Rotel RB1582 MKII.
    We both liked the Rotel better. Warmer and better controlled soundstage. This was also hooked to an Oppo 105 that many consider bright and analytical.
    As others have said, match your equipment to avoid too much of one thing.
  • soundfreak1
    I've desided to just keep the 1500 until something further up the ladder comes along.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • steveinaz
    steveinaz Posts: 19,546
    edited May 2017
    The Halo series is basically a rebadging of the HCA series. I better tell my 13yr old HCA amp it needs new capacitors....LOL
  • soundfreak1
    I'm just using it for biamping my bass at 350 htz and down.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • soundfreak1
    edited May 2017
    Used to have an recaped hca1200 driving RTA12C''S and it did a very fine job, then I found a krell amp and it was a whole new ball game.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
