upgrade to lsim705s and bridged behringer a500s.
  • arekon
    arekon Posts: 77
    DSkip wrote: »
    Might need a refresh but that's a lot of amp for the money.
    it appears that way.
    mixed online reviews but thats normal for just about everything.
  • DaveHo
    DaveHo Posts: 3,581
    I owned that Acurus for a number of years. Only replaced it because I came across it's big brother Aragon for a nice price. That Acurus is a nice amp. A no brainier at that price if working properly.
  • arekon
    arekon Posts: 77
    unless i get 'douched,' i will have the acurus 200x3 in my arms sunday morning. too hard to let it slip away as i did a few weeks ago with a rotel 3 channel
  • pearsall001
    pearsall001 Posts: 5,234
    Good snag...hope you get it.
  • arekon
    arekon Posts: 77
    so i got that acurus 200x3. it comes with a grounded power cord but is stamped with only a 60°C rating. i have a non grounded cord, same guage, but with a 105°C rating. all other cord specs between the two are the same.
    should i keep the factory cord from 1998 or use the new, non grounded cord from 2016?
  • lightman1
    lightman1 Posts: 10,796
    edited May 2017
    Temp ratings are a non-issue here. Gauge and grounding are. If you have grounded three prong outlets in the wall, use the three prong. Then, if you hear any noises that shouldn't be there......buzzing, hum, alien transmissions from your speakers....try the two prong to hopefully eliminate a ground loop.
    Can ya dig it?
    Edit: Because 60* C is about 141* F.
    If your house is that hot, go ahead and step up to the 105*C cable. Then call an HVAC repair company.
  • arekon
    arekon Posts: 77
    we live in igloos up here in canada. will stick with the 60 for now.
  • arekon
    arekon Posts: 77
    another doozy for you guys..
    will the rca cables play as big of a role as the speaker wires? i already have fospower brand in the closet.. ditch em?
    F1nut Posts: 51,674
    They certainly can as everything matters.
