Bi amping
Can I use a stereo receivers A and B circuits to bi amp a Monitor 30 pair?
    F1nut Posts: 51,781
    edited April 2017
    That is not bi-amping as that requires separate amps among other things. What you are purposing would be bi-wiring. You could do the same by running two pairs of speaker cables off the A binding posts. Netting the same basic results as what you purpose is to simply replace the stock jumper plates with high quality speaker cable.
  • mrloren
    mrloren Posts: 2,474
    Yeah what F1nut said
  • Unibit
    Unibit Posts: 45
    I could not hear any benifet from bi-wire, maybe just my set up.
    tonyb Posts: 33,072
    Unibit wrote: »
    Understandable....with Monitor 30's anyway. Thing with receivers....they have one power supply, a cheap one at that, and that power can be dished out all on speaker A or speaker A+B, but it's the same amount of power. Same with a HT receiver, same power, dished out over 2 channels or up to 7 channels.
    Is there something in the sound your wanting to improve on ?
  • gp4jesus
    gp4jesus Posts: 2,019
    spazmo wrote: »
    In a word No!
    *all connected w/Premiere ICs
    txcoastal1 Posts: 13,513
    gp4jesus wrote: »
    spazmo wrote: »
    In a word No!
    Jeez bro now you sound like Jesse :p:D:D:D
