What are these worth?
I have what I'm pretty sure are original SDA SRS speakers. How can I verify what they are, and how much are they worth?
Best Answers
    F1nut Posts: 52,009
    Answer ✓
    Indeed, you have the original SDA SRS. You can check past sales on eBay and Hifi Shark for values.
  • Nightfall
    Nightfall Posts: 10,083
    Answer ✓
    $1,000, maybe more on eBay.
    afterburnt wrote: »
    Village Idiot of Club Polk
Answers
    pitdogg2 Posts: 27,338
    edited April 2017
    4 bucks
    Look at interconnect socket if they are big blade small blade ...very likely SRS
  • Thanks guys, my dad bought them new when we lived in Germany in the '80s. Ive had them sitting in a closet for a few years. I'd keep them just for sentiment, but I'm moving and need to downsize.
  • lightman1
    lightman1 Posts: 10,797
    4 bucks
    $3.99
  • michaeljhsda2
    michaeljhsda2 Posts: 2,206
    edited April 2017
    The only way to say for sure is by checking the IC socket. Is it pin/blade or blade/blade? The label on the back is not reliable as Polk used up old stock parts on other speakers. If it's pin/blade you have SDA SRS 1.2's and they can be TL'd. If it's blade/blade they are Original SRS and cannot be TL'd.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • PolkieMan
    PolkieMan Posts: 2,446
    Or look closely or remove one tweeter
  • michaeljhsda2
    SL2000 tweeters will be in the original SRS and 1.2. That won't tell you anything. Interconnect socket is the only way to properly identify them.
    SDA SRS 2.3TL's
    SDA 2B TL's
