It's Krazy Karma time
124»
    billbillw Posts: 7,728
    I choose 109 for the BDA-2.
    Again, very generous giveaway. Thanks for thinking of us.
  • WLDock
    WLDock Posts: 3,073
    OK, this is an unbelievably generous Karma! ALL I can say if WOW! What a way to help elevate the audio journey of others. I got my first good listen of Bryston electronics and speakers last year and was really impressed.
    Anyway, just for clarity...I think I know the answer but. Will the drawing reset for each item? Meaning, a number (#2 for example) can be generated three times because the range will reset for each item?
    This:
    Pick between 0-299 for BDP-1, BDA-1, BDA-2 (Its not possible to generate the same number for each item)
    OR this:
    >reset
    Pick between 0-299 for BDA-1
    >reset
    Pick between 0-299 for BDA-2
    (It is possible to generate the same number for each item)
  • [Deleted User]
    [Deleted User] Posts: 10,716
    No fair asking questions. >:)
  • PSOVLSK
    PSOVLSK Posts: 5,397
    Unbelievable generous is correct.
    #4 BDP-1
  • PSOVLSK
    #4 BDA-1
  • PSOVLSK
    #4 BDA-2
    Thanks again.
  • BlueFox
    BlueFox Posts: 15,250
    WLDock wrote: »
    This:
    OR this:
    >reset
    >reset
    Three separate drawings; one for each item. So, the same number can win all three.
    As mentioned, if no one gets the exact number then I will redo the Karma, but reduce the available numbers to better the odds of the number being picked. This is like the Lotto, being close doesn't count. you have to pick the correct number. :)
  • WLDock
    WLDock Posts: 3,073
    edited April 2017
    #15 - BDP-1
    Mind!
  • WLDock
    WLDock Posts: 3,073
    edited April 2017
    #51 - BDA-1
    Blowing!
  • WLDock
    WLDock Posts: 3,073
    edited April 2017
    #201 - BDA-2
    Karma!
    Thanks BlueFox! Glad to have the chance.
  • teekay0007
    teekay0007 Posts: 2,288
    Incredibly awesome Karma, Bud!
    IN with 137 for the BDP-1.
  • teekay0007
    IN with 259 for BDA-1.
  • teekay0007
    IN with 28 for the BDA-2.
    Thanks for the opportunity on these three great pieces, Bud! Very kind of you.
  • BlueFox
    Krazy Karma is Klosed.
    Based on random numbers from https://www.random.org/ we have these winners.
    BDP-1. 68
    BDA-1. 241
    BDA-2. 156
    Now I need to go through all the entries and see if anyone got lucky. If there are no winners for any item then we will redo the drawing next Friday. However, I will count the number of people in today's Karma, and only allow a number range between 0 and X-1.
    IMPORTANT!!!!!!
    Only people in this Karma can participate in any future Karma for these items. That sounds fair to me.
    As usual, I will allow myself 24 hours to tweak the rules for the next Karma, if we need one.
    Giving away stuff is a lot of work. Thank goodness it is Friday since I can drink beer while doing this. :)
    Good luck.
  • BlueFox
    edited April 2017
    Okay. I did not see any entries for 68 for the BDP-1.
    Nor did I see 241 for the BDA-1
    No 156 for the BDA-2
    Ryan is right. Congratulations. :)
    Trying to do this on the iPad is too difficult, so tomorrow I will use the computer to cut and paste and create a list of all entries, and set the number range to that. I will PM everyone to insure they know they need to repick.
    Also, this time there will be one post with all three entries. That was a stupid idea of separate posts. Moron. LOL
    Finally, there were a couple of invalid entries with something like 'in with X'. I will let them know they need to do it right to win.
    Now, back to the Friday brewskis. :)
  • teekay0007
    edited April 2017
    BlueFox wrote: »
    ...tomorrow I will use the computer to cut and paste and create a list of all entries, and set the number range to that. I will PM everyone to insure they know they need to repick.
    Sounds like a lot of work, Bud. By the time this is done, you'll likely wish - if you haven't already - that you hadn't even started it.
    May I suggest just rolling the (300-sided) die again until you hit on a number that was chosen, for each of the three items, in succession?
  • trav0810
    trav0810 Posts: 1,056
    I missed the original entry. I was holding off til closer to the 28th and didn't know the date had changed. If we missed the initial entry can we still enter for the 2nd round?
    The difference between genius and stupidity is; genius has its limits.” -Albert Einstein
    Sony Playstation 3 for CD and Streaming
    Thorens TD320
    Modified Carver C-1
    Carver TFM 42 and 45 Amplifiers
    Polk RTA15TL Speakers w/Decato mods
    White Lightning Moonshine DIY Speaker Cables and Interconnects
  • quickr1
    quickr1 Posts: 414
    trav0810 wrote: »
    One of the revised rules was if you didn't enter the first drawing you weren't allowed to enter the second. It was just a couple posts up from here.
  • trav0810
    edited April 2017
    quickr1 wrote: »
    trav0810 wrote: »
    Ahhh...Ok. I wish I had noticed that the drawing time changed to the 21st. I thought I had till the 28th to get in. Bummer
    Thorens TD320
    Modified Carver C-1
    mhardy6647 Posts: 35,181
    better late than never?
    A heartfelt thank you to Bluefox for this very cool addition to the fold via Karma!
    It's installed & in use and working fine (not that I've done any more than use it for CDs).
    Howzabout youse other guyses?
