Hey Grimster74!!!! and anyone who knows!
landry_p2000
I am about to move into a new home, and since I am not renting anymore, I was wondering if you could give me the rundown on what materials used to hide wire into sheetrock. How do you run it?
Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD
Post edited by landry_p2000 on
Are you running the wire inside the walls? If so, a fish tape would helpful, but not necessarily needed. Elaborate more....Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
http://clubpolk.polkaudio.com/showcase/view.php?userid=40818 I think he wants to do what he did.SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop. -
I'm open to sugesstions. What would be the more affordable way? Cheaper? Tell me about fish tape.Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD -
That looks cool, but it also looks difficult also.Originally posted by dcarlson
Fish tape is a metal band that you use to "fish" cables thru walls. If you don't have any tight spots to fish cable thru, you probably won't need it. You slide the fish tape thru the route you want the cable to go, then attach your cable to the end of the fish tape, and reel it thru the walls. You'll find them at your local hardware in different lengths.
If you have accessible attic space and no cross-beams in the wall studs, it should be fairly easy if you have some basic carpentry skills. Just drill 1/2" holes in your header board and drop the cable down to where you've mounted your connection box. Drape the remaining cable in the attic over to the wall header where the cable will connect, and do the same.
Of course if you have a basement, you can always go thru floors instead of the attic approach.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Well damn, I almost missed this post. The speaker cable I used to run in and threw the walls was Monster cable. I purchased it with my employee discount when I used to work at BB part-time.
http://www.bestbuy.com/site/olspage.jsp?id=1051384781386&skuId=4223977&productCategoryId=cat08055&type=product
As far as the remaining material. Basic drywall spackle, spackle knife, just a typical junction box and a razor knife to cut the drywall. The hardest part of the whole process was waiting for the spackle to dry.Money Talks, Mine says Goodbye Rob!!!! -
I do some remodeling/trim work as a side business and I have helped some friends with their HT rooms. The easiest method I have found is to space out the baseboard trim with 3/4" or 1" spacers behind it, top and bottom, and run the wires behind the trim. Use trim head screws to fasten the baseboard through the top spacer, and you can pull the spacer out at any time to add or change the wiring. For wall mounted speakers, you can go from the cavity behind the baseboard, into the wall cavity, and come out of the wall cavity behind the speaker. If you move the wall mounted speaker, you only have a small hole in the wall to patch, as the hole in the wall at the bottom is behind the baseboard trim.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Thanks for the input guys, these are all excellent ideas. I will let you all know when I get it done. That "fish tape" sounds like the easiest route to take.Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
there is also fake plastic baseboard wire-duct that can be painted, same as above, just no caprntry and more money
___________________________
Total cost of materials: Going up...
Time spent: Countless Hours...
Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
For some things in life, you pay others to do it... For a masterpeice, do it yourself. -
YES! Another very good idea. I used Panduit to run my sub-woofer cable above my baseboard, you'd never know it.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Ditto for crown molding now....Originally posted by LittleCar_w/12s
landry,
While grimster's solution is very effective, you are still carving out a lot of drywall to make "valleys" for the wires.
dkg999's approach is really no more difficult... and you still get to play with a "fish tape" for the vertical runs from the baseboards up to the speakers...
Easiest by far, if available, is the attic route with drops to each speaker location... and you can "fish" with a coathanger...
Grimster,
Is your setup in a basement with cinderblock behind the drywall?More later,
Tour...
Vox Copuli
Thanks Tour,
I am going to horse around in Home Depot for a while, and see what I can find. Is any one familiar with the adhesive backed tubes used to run computer or phone lines up a wall? These are plastic, paintable, hollow tubes that would be pretty easy to install. My only thing with this option there would be a hump on the wall. It may not be a problem once I dicide what color to paint my HT room in the new house. I got everything wired, and the three wall speakers are my only problem left. They are just hanging on the wall with the wire still showing. I gotta move fast and employ some sort of camouflage for the wires. Thanks for the input fellas. I got a better feel for what I should do now.
Good guess, I guess...
End product looks very, very nice...More later,
Tour...
Vox Copuli
