shaving
Willow
I am thinking of going to electric razor as I have sensitive skin and very coarse hair which leaves me with morning battle wounds almost every day.
For peeps who have gone from blade to electric how did you find it ? any good razors out there ? anyone know the diff between the three circle razors and the straight across one ?
thanks for the info
and I don't need tweeks and mods for the electric razor
thanks
JF
thanks for the info
thanks
JF
thanks for the info
thanks
JF
I also have course facial hair, and have yet to find an electric that does anything good. I've found I'm cut much less when I use the "Mach 3" razors though... sounds gimmicky, but they really do work.
If you do find an electric that works well, post it, cuz I've wasted more money....If you will it, dude, it is no dream. -
I am half Italian, so what is a 5 o'clock shadow for most is more like an 11:45 shawdow for me. I also seem to have thin, sensitive skin.
I switched over to an electric about 4 years ago. It is a Norelco, but I forget which model. It has the 3 circles.
Here are my tips:
1. Stay with it. The first week or two will be horrible. Very irritating to the skin, and hard to get a close shave. After a good week or two, your skin will adjust to it. Once you have adjusted to it, it is SOOOOO much better than a razor blade.
2. Shave BEFORE you wash your face/take a shower. Your skin must be dry & smooth. If you wash your face/shower, your skin is not as smooth, and the razor will not glide across very well.
3. Don't spend too much time on one spot. Keep the razor moving. Don't press too hard. Just let it glide across your face.
4. As with a blade, I always wach my face with hot water or take a shower afterwards.
Hope this helps. The most important thing I can tell you is to stick with it. At first you will think it is a mistake, but you will grow accustomed to it.Bob Mayo, on the keyboards. Bob Mayo. -
Good lord, we discuss anything and everything on this board.
Too funny!
I used an electric razor a few times. SUCKED! Burned my skin and got a crappy shave.
I like the Sensor Excel razors the best. Gives me a "Smooth as a babies ****" shave everytime!
JohnNo excuses! -
I currently use Mach 3...thanks every one for the info and I will stick to it once I get one -
I've almost always used electric. I prefer the straight kind, didn't really like the circled one. I think the straight makes it easier because it's like you're shaving with a "real" razor.
I use a Pre-Electric shave gel from Afta and it helps out alot, makes your face nice and smooth for the razor to run over and it seems to give me a much closer shave.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
I saw a big nasty fat lady the other day with a full mustache. Not just that "menopause" cookie duster thing, but a full on stache. I almost puked. What does that lady think when she looks in the mirror, it looks good? Stupid people....Bob Mayo, on the keyboards. Bob Mayo.
LMFAO!!!
I hates chicks in general that don't rid themselves of the 'stash.
Wax that thing ****!!!No excuses! -
HA HA! Nice John! Where you work there's probably not too many ladies that have any hair left to wax!Wax that thing ****!!!
There is a "female" cashier at the local Wal-Mart that has a full peach-fuzz BEARD! some of the hairs on her face are a few inches long. :eek: What the HELL is she thinking?Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
I shave my entire body so I don't color the sound of my gear.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I heard a bald head is not good for room acoustics !! -
Have you tried the old "safety razor"? I went back to it from the disposable razors and it helped. Of course you have to be more careful with it but the blade is much sharper and cuts with ease. I hate the three blade disposables (Mach 3's and such), I find it easier to shave with a single blade.
Try the new Shick(sp?) Quattro Razor. 4-Blades so it should give a closer shave. I havent tried it yet cuz I have no problems with Mach 3 but give it a go, you might like it.
Maybe I should just have the hair on my face lasered (??) smoove as baby butt all the time !!
I have that Razor!
The Quatro or whatever...
Works well, until you dull the blade, then they are like 6-7 dollars for 4...
Anyways...
Only way you can cut yourself with that razor is to go sideways...only way...
Mach 3, etc - I have had no problems...
The cheap disposable things...I cut myself 2 or 3 times- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
is the Quattro any better then Mach 3? I might consider switching. Does the Actual Razor thing swivel up and down like the Mach 3?
I like the Quatro ALOT better than the Mach 3...
As for swiveling...yes it does...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
the only quattro Ill have is the audi......(well in my dreams maybe)
Anybody tried that new Mach 3 razor with that 'electro-magnetic thing' that brings the hair up to make it easier to cut?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
who the hell wants a vibrating razor near their juggular -
Braun electric cord/cordless.
Works good enough with no irritation.
Youll save money in the long run.
More $ for audio gear!
GHT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
I use the electric clippers that barbers use to shave my face. Andis brand. It works pretty good and I never get bumps or war wounds. It doesn't always give a perfect clean shave but it's good enough for work.Main system:
Fronts: Infinity Alpha 50
Center: Infinity Alpha 37c
Surrounds: Infinity Alpha 20
Receiver: Onkyo TS-XR607
Subwoofer: Pioneer S-DW1-K
Cable- Monster Cable XP
Bedroom Setup:
fronts- Polk R50
surrounds- Polk R30
center- CS1
sub- Sony 50 watt
AVR- Onkyo TSXR502
Cable- Monster Cable XP -
You could... While you're at it, you could also get your scalp lasered to save on haircuts
Do you have to shave?
If you must... I used a Panasonic Wet/Dry electric for years. Shave in the shower, lather up.. no irritiation...More later,
Tour...
Vox Copuli
Yes or I get no love from my wife !! oh yes and of course I need to shave for work -
I make it a point to NEVER date a woman who:
1) can beat me in golf
2) can bench press more than I can
or
3) has a better mustache
All others are fair game
2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
or
who has a deeper voice than me..... -
If you go electric, you'll have to pick between the straight and swirly. I tried switching from Norelco to Braun but it could never cut as well as the Norelco. My problem is I don't clean and replace the blades enough so I spend more time swirling. The pre-electric stuff works well too. If you have zits, electric is less painful? hehe
I use mach 3 when I need the closet shave, but like others I get a 5 o clock shadow within hours of shaving....
Laser hair removal is not permanent, read the fine prints
Who has an Adam's Apple or who's hands are larger than mine.Originally posted by Willow
Hey I use the Extreme 3 by Schick. These babies have aloe strips for soothing shaves. Try them out.:DMain Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD -
May be too late, as I already posted in this thread, but we are talking about faces here... Aren't we?More later,
Tour...
Vox Copuli
