Broke my Monitor 7bs, what can I fix it with
dan98svt
Not even home yet, and I get the bad news. Granddaughter knocked a 7b on its back and the speaker plugs caved in the back plate.
This doesn't look repairable. What can I replace it with? Only see one 7b crossover on fleabay (without the fuse). Will I need a matched set? Will the 5b or 5b jr set work, or will that be a noticeable downgrade? I saw some 11 crossovers, but they have 2 woofers. I don't think that will work.
Ouch. So yours have fuse, that's what you're saying?
Ouch.... Mount them to a plate.Don't take experimental gene therapies from known eugenicists.
no fuse
Well by an old cup/crossover with no fuse move your xo to it or buy some plates. Some here have made some out aluminum but then you wind up with needing new binding post and so forth. Can get pricey in a hurry. Xschop is your man.
Yeah, didn't think of that. I'll have to take it apart when I get home next week. Hopefully only the cup is kaputt.
All kinds of crossovers on eBay. Buy one just for the cup if that is all you need.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
Idolizing a politician is like believing the stripper REALLY likes you. -
I have a set of M7 crossovers over at my storage I will grab in the morning. If they will work you are welcome to them for the postage. For the SL-2,000 tweeters and pretty sure mine have the polyswitch.Post edited by littlewoodboats on
littlewoodboats wrote: »I have a set of M7 crossovers over at my storage I will grab in the morning. If they will work you are welcome to them for the postage. For the SL-2,000 tweeters and pretty sure mine have the polyswitch.
Very kind gesture, LWB!
If it doesn't work out with Steve I've got two plates you can have. They were from my 7B's, so you'd have to plug the 3 holes from the fuse holder and epoxy your large inductor/crossover to them, which is doable.Political Correctness'.........defined
President of Club Polk -
I would also be worried about magnet shift on the drivers...
Once again...Club Polk guys to the rescue ! Cant beat them !
Here are some images along with the serial numbers of the cabinets they came out of. I remember now why I pulled them as one did have a broken binding post. You will notice the bobbins are out of the crossovers as I had thought of using them in another project. I can put them back without issue. If you see you have a shifted magnet I have a spare driver. I will send it along with the condition you send yours to @lawdogg for repair to be sent to me for a replacement. The spare here has the magnet glued with dynamat on the basket
Misfire on the images
What a difference a few minutes and a scrounge through the parts drawer can do. I knew I had some binding posts laying around so put those in while the boards were loose. What I did not remember was having a pair of Dayton caps in the correct value. The boards both had 12uf caps but one was 250v while the other was 100v. Now they match. I tried to karma those Dayton's a while back with no takers so went ahead and tossed them in.
If memory serves I ordered the Dayton's to bulk up an order just enough to get free shipping on some other parts -
What happened to the granddaughter?
Disinherited?
Maybe give her favorite doll a buzz cut so she gets the point.I disabled signatures. -
littlewoodboats, thanks for the offer. Very kind.
The granddaughter is too lovable to be mad at. She knocked one over before and froze a woofer. I bought 2 and replaced them both. Hopefully it survived this fall.
F1nut, thank you for the offer too.
Do you still have the frozen driver? In many instances they can be realigned.
I may. I tossed some out. I've replaced 7 so far in all my Polks...
Dan, I fix them if ever interested. I also take donations to use for other people.
Also, do you have a Mustang or a Contour?
my 3.1TLs
I will fix your shifted magnets for free.
lol, had a contour
I'll quit tossing the old components in the trash. I have 12 SL2000s sitting in a drawer. Was going to eventually put them on fleabay.
lol, had a contour
Silver, Red, or Black? My user name is the factory paint of my '99 SVT (silver frost). Was a great car for my bachelor days.Jay
Used to autocross with some SVT Contour folks. Y'all are a crazy bunch.
my 3.1TLs
These are in route to my brother in arms serving overseas. Free of charge.
I fooled everyone here. Ignore my cap karma will youse guyz? I showed all of you and finally managed to give these away.
Last laugh is mine. Haaaaaaa.........
Thank you littlewoodboats!
Dan -
Had a silver SVT Contour. Brought it to Germany and found out there is no governor on it. It maxed out just a bit past the 160 mph mark, and counting for speedo error, was still probably over 150 mph. Had it for 10 years. Unfortunately, the rust ate the car alive. Started having electrical problems too, kept shutting off while driving. Ended up trading it in, getting $2500 for it.
Finally home. Going to take the cup off and check the damage. The woofer still floats, glad I replaced on both speakers when I did the last one.
