how does this sound
Systems
Systems Posts: 14,872
edited October 2004 in Car Subwoofer Talk
ok i sold all i polk gnx subs and my amp.im thinkin about gettin 2 12 inch image dynamic ID12 V.3 in a dual 1.25 q-logic box witch is sealed powerd by a JBL BP-600 1Z mono amp off sound domain..how do you think that would sound???????my buddy got 2 jl w3 powerd by a kicker amp and im tryin to get louder than him would thes subs do it????
Testing
Testing
Testing
  • Systems
    edited October 2004
    sorry bough the double post i had a prob with the computer when i was done
    Testing
    Testing
    Testing
  • exalted512
    exalted512 Posts: 10,734
    edited October 2004
    how much power does he have going to his JLs?
    the v3s are some of the best sq speakers on the market--great stuff...light years ahead of the gnx's
    im sure youll be more than pleased
    -Cody
  • Systems
    edited October 2004
    he says hes got a 900 watt amp its a older amp.im not sure what his gain is set on.will the image dynamiks hit real real low since they go to 10hz and the amp goes down to 10hz??
    Testing
    Testing
    Testing
  • neomagus00
    neomagus00 Posts: 3,899
    edited October 2004
    if you're going just for loud, go for a ported box, at least. if you want sq along with loud, you've picked a good sub, still go ported. if you just want volume, there are better spl subs out there; i think pioneer has a line, i dunno who else, this isn't really my deal.
    the amp had better go to 10 hz, and way above 20 kHz, or else you're getting shafted. what do you mean it goes down to 10 hz, the sub? linear response? cause that's pretty damn good... but it really depends upon the box you put it in. again, for spl, go ported, and set the tuning frequency relatively high - say 50 Hz. this will not play deep, and in fact you'll wreck your subs (no matter what kind they are) if you try to play them deep in a ported box. you could go sealed and get pretty low notes, but the lower you want, the quieter it'll be.
  • Systems
    edited October 2004
    i want somthin that pounds the hell out of ya.i wanna feel it in my chest and pick up the deep notes would to kicker comp cvr do it???i had 1 kicker comp cvr and it was danm good
    Testing
    Testing
    Testing
  • MacLeod
    MacLeod Posts: 14,358
    edited October 2004
    If you want sheer SPL I would also go with a ported but that would pretty much require you build it yourself as they have to be tuned to the sub usually. You can stay with sealed, the difference is usually not that much, around 3-5 db.
    As far as SPL subs, ID wouldnt be my first choice unless youre going with an ID max.
    This is what Id recommend. Go here and check out the P12. Get 2 of those and power them with this MTX amp. I guarantee ya, you put them in the right box and itll smoke most cars out there.
    Now if you wanna spend a little more scratch, you can go with the Orion H2. You can go with the 10 or 12 depending on how much you want to spend. Personally I think it would be cool to go with a single H2 10 and push it with this hoss. This way youd be smoking most systems with only a single 10!
  • Systems
    edited October 2004
    hot about 1 12 inch adire brahma hooked to a 1200 watt mono jbl amp????
    Testing
    Testing
    Testing
  • Joelsbass
    Joelsbass Posts: 637
    edited October 2004
    that would definately be a good plan:D
    MacLeod: I guess youre lucky Polk has such lax hiring standards.
    Josh: Damn skippy!
  • exalted512
    edited October 2004
    agreed
    -Cody
  • Systems
    edited October 2004
    allright thats probably what im gonna do get the amp in a couple weeks then save my money up and get the adire 12 inch brahma..should i buy one of them ported godzilla boxes off sounddomain for it???
    Testing
    Testing
    Testing
  • neomagus00
    edited October 2004
    if it's not made just for the brahma, don't get it. if you have absolutely no way to do it yourself - i.e. a decent saw and some time, a power drill is good, if not, good forearm strength is a must - consider it (if it's made for the brahma). if you can do it yourself, do that, by all means - you can customize it to your tastes and car much better.
    why ported?
  • exalted512
    edited October 2004
    if you cant build your own
    either here:
    http://www.carstereousa.com/subwoofer_boxes.htm?qty=1.00%E2%8A%82=106.00&shp=0.00&dis=0.00&vch=0.00&tax=0.00&tot=106.00&sd=
    or here:
    http://sound-foundations.us/catalog/index.php?cPath=50_55
    any other premade box will NOT be able to properly house a brahma
    -Cody
