speaker wire pins
Willow
are these to be used when you have speakers with clips ? or can they be used on binding posts ?
Post edited by Willow on
Yes for spring clips, certainly you can use them in binding post. they will be a bit small and not the tightest fit, but inserted into the hole and tightened with the nut will work.. if thats all you have to work with.MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
thanks. I have nanners on all mine but I have 12 new pins lying around and never really knew what they where for...til now
Best use is for holding a pair of olives together in a martini...
Cheers
More later,
Tour...
Vox Copuli
Nah !! not big enough to hold the olives in my martini
i've used needle nose pliers to bend a curve on the end to fit into the binding post. the fit is snugger than straight pins and the lugs don't come loose as they sometimes do with straight pins.
