This should look pretty sweet,
«13
  • You gonna let me machine these guys? B)
    Toolfan66 Posts: 18,191
    edited March 2017
    Hint: They are 1 inch thick.. 13.5 x 22.5 B)
    Brian can't play, but yes you can..
    F1nut Posts: 52,011
    Guess I better find a box here quick like.
    pitdogg2 Posts: 27,343
    edited March 2017
    Hmmmm...
    I'm stumped.
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited March 2017
    OK, Larry, what's up?
  • deucekazoo
    deucekazoo Posts: 146
    A metal enclosure for the SDA CRS?
    Polk S10, S8, S4
    Polk RT8
    Polk Monitor 7s
    Working on getting SDAs
    xschop Posts: 5,417
    XS-CRS
    F1nut Posts: 52,011
    Ah, thought those dimensions were a bit off for CRS's.
    edited March 2017
    End caps for sda's :wink:
    EndersShadow Posts: 17,723
    Aluminum sub box....
  • Gerres26
    Gerres26 Posts: 874
    Cant wait to see these
  • motorstereo
    motorstereo Posts: 2,371
    Awesome!! I'm thinking those are some very expensive end caps and you'll be the only kid on the block with a set for sure.
  • ptrooper
    ptrooper Posts: 501
    edited March 2017
    Very interesting. I contemplated ali end caps a year ago and it should look **** hot with black grill cloth ,will you also be doing the same with the side trims Larry?
    nooshinjohn Posts: 26,002
    If you are making end caps, might I suggest that you mod the bases to accommodate some sort of spike system that allows for leveling without having to be under the speaker to do it? Put me down for a set of caps and side panels please.
    Good call John.
    edited March 2017
    Yes I'm doing the side panels as well, I haven't decided if I'm going to:
    1)Brush finish them, then clear coat them (powder coat)
    2)Brush finish, Red anodize them like my face plates..
    3)Have them powder coated Red with a clear coat finish..
    Keep in mind I will be doing the tweeter bezels, trim rings around all driver, and passives, and if I don't do red anodizing I will be redoing the x-over plates as well, I want it all to match..
    This should be fun, and something different... :-)
  • monepolk
    monepolk Posts: 1,154
    Very interesting
  • ptrooper
    ptrooper Posts: 501
    getting a woody :p
    ptrooper wrote: »
    getting a woody :p
    Nope... getting "METAL" lol... no wood here....
  • motorhead43026
    motorhead43026 Posts: 4,031
    ^^also known as a Steely Dan.
    My god Larry talk about stepping it up. Steller idea's from a genius mind
    xschop Posts: 5,417
    Are you going to copy the factory corner radii or change them up a bit?
    F1nut Posts: 52,011
    Not that it matters, but I vote no to the red idea.
  • ptrooper
    ptrooper Posts: 501
    brushed aluminium all the way
  • lightman1
    lightman1 Posts: 10,797
    edited March 2017
    Y'all see this?! Larry comes in here and fooks up the program. We have (what we thought of) a nice set of speakers. Then he pulls this stunt. For Q Larry.
    I would be in for a driver ring that improves the look of the ugly baskets as well.
    Urushi black finish would be amazing
