This should look pretty sweet,
Toolfan66
You gonna let me machine these guys?
Tease!
Hint: They are 1 inch thick.. 13.5 x 22.5
Brian can't play, but yes you can.. -
Guess I better find a box here quick like.Political Correctness'.........defined
President of Club Polk -
Hmmmm...
I'm stumped. -
OK, Larry, what's up?Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
A metal enclosure for the SDA CRS?Polk S10, S8, S4
Polk RT8
Polk Monitor 7s
Working on getting SDAs -
XS-CRSDon't take experimental gene therapies from known eugenicists.
Ah, thought those dimensions were a bit off for CRS's.Political Correctness'.........defined
End caps for sda's
Aluminum sub box...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Cant wait to see these
Drool!
Awesome!! I'm thinking those are some very expensive end caps and you'll be the only kid on the block with a set for sure.
Very interesting. I contemplated ali end caps a year ago and it should look **** hot with black grill cloth ,will you also be doing the same with the side trims Larry?
If you are making end caps, might I suggest that you mod the bases to accommodate some sort of spike system that allows for leveling without having to be under the speaker to do it? Put me down for a set of caps and side panels please.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »If you are making end caps, might I suggest that you mod the bases to accommodate some sort of spike system that allows for leveling without having to be under the speaker to do it? Put me down for a set of caps and side panels please.
Good call John. -
Yes I'm doing the side panels as well, I haven't decided if I'm going to:
1)Brush finish them, then clear coat them (powder coat)
2)Brush finish, Red anodize them like my face plates..
3)Have them powder coated Red with a clear coat finish..
Keep in mind I will be doing the tweeter bezels, trim rings around all driver, and passives, and if I don't do red anodizing I will be redoing the x-over plates as well, I want it all to match..
This should be fun, and something different... :-)
Very interesting
getting a woody
^^also known as a Steely Dan.Patriotism is the last refuge of a scoundrel…….Samuel Johnson
– Kevin Alfred Strom -
My god Larry talk about stepping it up. Steller idea's from a genius mind
Are you going to copy the factory corner radii or change them up a bit?Don't take experimental gene therapies from known eugenicists.
Not that it matters, but I vote no to the red idea.Political Correctness'.........defined
brushed aluminium all the way
Y'all see this?! Larry comes in here and fooks up the program. We have (what we thought of) a nice set of speakers. Then he pulls this stunt. For Q Larry.
I would be in for a driver ring that improves the look of the ugly baskets as well.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Urushi black finish would be amazingThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
