rpm goes from 1000-2000 untill the car heats up
Systems
hey guys i know this is probably a question that i should not be asking here but u guys are the only ppl who really answer the questions right and not try to mess the other guys up and ive tried a lot of forums. neways my question is that...i have a 95 acura integra when i start the car the rpm goes from 1000-2000 back and forth with me not even pressing the accelerator neways i cant seem to figure it out if anyone knows please let me know cause its driving me crazy
thanx
thanx
Testing
Testing
Testing
Testing
Testing
I know very little about your vehicle but, the problem you describe is all to common. In general the engine loping that you are describing is most commonly caused by carbon buildup in the throttle body. Hope this proves helpful.
As suggest by AutoZone
Priority Action Part Type Cause
1 Inspect AIR FILTER Restricted or clogged air filter.
2 Inspect FUEL FILTER Clogged or dirty fuel filter
3 Inspect CHOKE PULLOFF Worn, defective, or faulty choke pulloff(s).
4 Inspect CHOKE THERMOSTAT Stuck or improperly functioning choke thermostat.
5 Inspect CARBURETOR FLOAT Improperly adjusted/saturated or damaged carburetor float.
6 Inspect CARBURETOR/FUEL INJECTION GSK Deteriorated, or faulty carburetor/throttle valve mounting gasket.
7 Inspect EGR VALVE Clogged, dirty or improperly functioning or defective egr valve.
8 Inspect FUEL PUMP Improperly functioning fuel pump or circuits.
10 Inspect FUEL TANK Contaminated fuel from rusted or deteriorated fuel tank.
12 Inspect IDLE AIR CONTROL VALVE Damaged, loose, or faulty idle air control valve.
13 Inspect IDLE SPEED CONTROL ACTUATOR Damaged, loose, or faulty idle speed actuator.
14 Inspect M.A.P. SENSOR Improperly connected or faulty m.a.p. sensor.
15 Inspect PCV VALVE Plugged or damaged pcv valve.
16 Inspect THROTTLE POSITION SENSOR Faulty throttle position sensor or throttle position sensor circuit.
18 Inspect FUEL INJECTOR Plugged, dirty or poorly connected fuel injector. -
my mom's honda odessey does the same thing, though it doesn't jump a thousand rpm... the dealer has no freakin clue what does it, but at least you know you're not alone
p.s. if you figure it out, p.m. me, yah?It's not good, very fundamentally simply not good. - geolemon
tell here next time by a ford.
j/kTesting
Testing
Testing -
BS. The problem is specific and has a fix. Be methodical as you address each possible cause. Any mechanic that can't solve this specific problem is either incompetant or preying (for profit) on your ignorance.
thanx guys for now i gotta write an essay but im gonna go through that list on thursday btw how do i check the fuel system?
and theirs a few other things that might be hard to get 2Testing
Testing
Testing -
This will get you started.
Make the $20 investment you wont be sorry.
HAYNES 12021 - Integra & Legend Models covered: All models of Integra - '90 thru '93, Legend - '91 thru '95. -
he's got a 95 integra though... unless you had a typo he'll need a different haynes manuel... just go to autozone and find the one for your car... or go all out and drop a good 120-150 into it and go to a dealership and get the actual service manuel for the car... much more detailed and vehicle specific...
and is it just me or does Ronald seem to struggle with his homophones.....MacLeod: I guess youre lucky Polk has such lax hiring standards.
Josh: Damn skippy! -
no, it's not just you, and good thing you know how to spell...
lol, my spelling is FAR from impecable, i just manage to avoid the more obvious mistakes
Helms makes manuals for most dealers.
Most Manuals are Online. The acura they all are online PDF format. It just a matter of finding the Right Site. Its around 1400pages of Information. Most Hybirds Honda/Acura has them.
Dont buy the cheap Chiltons waste of money.Testing
Testing
Testing -
I forgot English. Remember I am from Britian. Excuse my language ****.Testing
Testing
Testing -
Yeah yeah, thats great...
I personally can excuse your language...
However I am having a very hard time finding an excuse for you...:p
Anyways...I dont know squat about cars, so I will keep a track on this thread incase I run into a similar problem with my future cars...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
They don't speak English in Britain?Originally posted by ronald
I forgot English. Remember I am from Britian. Excuse my language ****.It's not good, very fundamentally simply not good. - geolemon
yeah..... ummmm.... isn't britain where english comes from???
i'm just gonna sit her laughing quietly.....:cool:MacLeod: I guess youre lucky Polk has such lax hiring standards.
You spelled "britain" shouldn't it be BRITAIN??
We speak British sucka. Ok I am not British. April Fools.
Testing
Testing
Testing -
it's actually impeccable...with 2 C's...Originally posted by Joelsbass
http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Ascendant Audio Atlas 12
2 Gallons SecondSkin Spectrum V.2 -
Now he has no clue what month it is either, so it becomes obvious that he lives out of touch with reality.
On the topic, though, my car does the same thing between 1 and 2krpm. I've never isolated it, and it's been 5 years. oh, and it's had 3 different engies, and it remains there.
The only reference I have found on this line in my car is a bad solder point on the ECM... I kick it and it runs better, sometimes. Maybe look on a few forums, though most car forums are'nt very active.___________________________
Total cost of materials: Going up...
Time spent: Countless Hours...
Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
For some things in life, you pay others to do it... For a masterpeice, do it yourself. -
i don't get it... though you did spell it britian in your first postOriginally posted by ronald
and my point is proven
Yeah, I thought that was a perfect demonstrationOriginally posted by Joelsbass
Alpine 9815
Why would there be carbon build up in your TB?
