SDA1 on craigslist $100
[Deleted User]
[Deleted User] Posts: 11
edited March 2017 in Vintage Speakers
reportedly in very good shape not used much, plan to hear them soon. Asking $100 for the pair. My concern is, they are rated 4Ohms, I plan to drive them with onkyo theater receiver 100W/ch. Is there a possible problem?
thanks
  • daddyjt
    daddyjt Posts: 3,158
    edited March 2017
    $100 is a steal. Running them with an AVR will not produce the best sound however, and the 4 ohm load will tax your AVR. they really need a dedicated amplifier to make them sing.
    ― Aleksandr Solzhenitsyn
    nooshinjohn Posts: 26,021
    daddyjt wrote: »
    This.
    F1nut Posts: 52,052
    You'll see the magic smoke rising from your AVR in short order.
    pitdogg2 Posts: 27,436
    Problem is they start at 4ohm but dip lower than that. Be very careful with the volume knob. I speak from experience here. I roasted two very nice receivers that pushed more than 100 wpc.
  • thanks for the comment, I noticed sensitivity if 94dB, so hopefully will be loud enough...
  • Legender
    Legender Posts: 478
    I'd get them as it's a steal and then upgrade to an amplifier feeding them instead of the AVR.
    Pretty sure it's not the loudness you should be worried about.
    Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
    Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
    Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
    2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
    Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
    Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra
  • K_M
    K_M Posts: 1,631
    edited March 2017
    A sensible precaution to take.
    Also many Avr's have different impedance selections, 6/8 ohms usually.
    The 6 ohm setting, will limit the "power", but provide more protection.
    The 8 ohm setting is actually the better one to use, as it does not artificially limit the power, but will cause receiver to get much warmer at the higher levels it allows.
    As long as you are using reasonable volume levels, AND it has decent air circulation, you will be okay.
    The problem with that philosophy of keeping the volume levels down is.....nobody buys big floorstanders without wanting to push them. It's human nature to want to turn up the volume when your favorite song is playing. Plus your not going to get those details in the music at lower volumes without sufficient power.
    This is when disaster strikes when under powering your speakers. Any 4 ohm speaker deserves an amp for it in my book. Right tool for the right job as they say.
  • K_M wrote: »
    This is not always the case. I let the smoke out of a Yamaha CR-1040 with a pair of SDA 2a's, volume at less than 25%.
    I had brought the 2a's home and listened to an entire Little Feet disk just running as a stereo pair with no issues. Using a clock face as a reference I ended up with the volume at about the 10:30 position. I shut everything off and put the interconnect in place to listen to the same disk again.
    Using the same clock face reference I had it at about 8:45 and blew the left side output module in the 1040 about half way through Dixie Chicken.
    Be careful and read your receiver documentation regarding output loads. Even if your receiver has a 4 ohm rating I would personally still not risk it. YMMV obviously
  • [Deleted User]
    [Deleted User] Posts: 365
    edited March 2017
    I ran a modded pair of SDA SRS 2s for a few weeks with an Onkyo 100 watt receiver with no problem and it didn't even get unusually warm. And, yes, it was turned up !
  • K_M
    K_M Posts: 1,631
    edited March 2017
    K_M wrote: »
    Great advice, what may work with one AVR/receiver, may not with another, and I am sure we are all using different levels as what we consider loud, not loud and so on. Room size, and many other things.
    TForan wrote: »
    Kinda like saying I did 50 mph in first gear and didn't blow my engine. That just means you got lucky, not that it should be standard practice.
    Can you run a 4 ohm speaker on a low powered AVR not even rated for 4 ohms ? Of course you can, but you have some risks your taking. Now, if money is of no concern to you, by all means, rock your world driving 4 ohm speakers with a AVR. Maybe you'll toast something, maybe you won't. One thing is for sure though, no 4 ohm speaker will sound great on an AVR.....and why buy a 4 ohm speaker, or any speaker for that matter, if you don't want to realize their full potential.
    This is why we don't recommend it, not that you can't do it, just that it's not good advice if you want to retain the integrity of your gear. See what I'm sayin' ?
  • K_M
    K_M Posts: 1,631
    gychang wrote: »
    thanks
    Gotta ask, what exact model?
    K_M wrote: »
    gychang wrote: »
    thanks
    Speakers are SDA 1, the receiver model.....does it matter ? Even the bigger ones limit current to retain a 4 ohm rating. That's to keep them from overheating, so regardless of the model receiver, it's a bad choice to drive 4 ohm speakers with an AVR. Just my .02.
    You can maybe get away with driving surround 4 ohm speakers with an AVR, they don't do much heavy lifting anyway, but as fronts....I'd nix that idea.
  • tonyb wrote: »
    TForan wrote: »
    It was just a regular two channel receiver, not a AVR. Just relating my brief experience with an amp that I was told wouldn't work with the Polks. It easily ran the speakers at over 100 dbs for hours. Maybe the Onkyos are more rugged than most receivers ? It did sound better with the Parasound Integrated but it wasn't night and day. I Paid $80 brand new Onyko ten years ago, so I wasn't too worried about its' well being. Still have it and it still works!
  • DSkip wrote: »
    Stereo receivers usually have a beefier power supply than their AVR counterparts. It still isn't ideal. The problem with running amps like that isn't always ruining the amp, but destroying your tweeters and midwoofers in the process. Dirty power is deadly to those components and when you are using a weak power supply, you get dirty power when pushed.
    Certainly not ideal, but it worked . That's all.
  • K_M
    K_M Posts: 1,631
    edited March 2017
    tonyb wrote: »
    K_M wrote: »
    gychang wrote: »
    thanks
    Oh was asking model, cause they were $100.00, nothing to do with the receiver thing, did not see the model listed, was going back to what the OP brought up was all.
    SORRY< just saw it listed in Title.....oops!
  • daddyjt
    edited March 2017
    This whole issue can be summed up as "Just because you can, doesn't mean you should..." you can sometimes cheat the laws of physics, but you can't beat them.
  • K_M wrote: »
    I would be interested in knowing which model as well. For a $100.00 they could be parted out at a profit or held onto until safe to use.
  • daddyjt wrote: »
    On the other hand, never miss a chance to blow those hideous SL2000 tweeters.
    J/K but I never could figure out how they ever let them out the door.
  • K_M
    K_M Posts: 1,631
    K_M wrote: »
    The title says....I missed it also..>SDA-1
  • But which one of the 1's as there were numerous ones? (Or should that be 1's)
    most likely SDA1 or 1a do not believe SDA1c are 4ohm..
  • pitdogg2 wrote: »
    So at the minimum the op is looking at eight midwoofers and two pr's for $100.00? Sounds like a steal to me.
    Yes stole them. I paid 124.00 for mine and old owner hacked into wires to get both tweeters working because he had no cable....genius at work step back lol
  • Maybe not so risky, after all. :)
    Quoted from the Polk website "The SRS Series was designed and engineered to be driven well by practically any electronics available at the time, even the most modestly-powered amplifier or receiver . They present an "easy load." We recommend that a high quality amplifier or receiver of at least 50 watts per channel be used for the best performance."
  • Ricardo
    Ricardo Posts: 10,634
    These are not SRS. And pretty sure some SRS were 8 ohms.
    SOPA
  • Ricardo wrote: »
    Weren't they all 4 ohms until the fourth generation ?
