I need help deciding what series are my speakers and what tweeters to get
I got a pair of polk monitor 7s need help on deciding what tweeter i need that will fit my speakers and it would be nice to know the series to :smiley:
The tag Reads Polk audio Monitor 7 24198 Thanks
    F1nut Posts: 52,105
    Post a picture with the grill off.
    I currently have goldwood tweeters from parts express and they suck
    Here is the crossover
    F1nut Posts: 52,105
    edited March 2017
    Whoa.......they are a bit of a mess. Ok, there is no fuse on the back, so they are likely 7C's, but you should pull the crossover to compare with the schematic posted here.
    Those driver/PR screws are not the correct ones and the driver screws are in the wrong location. It also appears the binding post plate is cracked. I can't tell for sure, but it appears the two bottom screws on the tweeter are going through the bezel, not the tweeter cut out.
    I take it you just bought them?
    One other thing, the red (positive) nut should be on the left, black on the right. However, you should verify that the wires haven't been swapped inside.
  • skrol
    skrol Posts: 3,474
    It looks like someone replaced the tweeter with a JBL (or knock-off) tweeter.
    If you remove the PR and snap a pic of the actual crossover components we maybe able to give a better idea but you likely want the Polk replacement tweeter RDO-194 which is an upgrade.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Nightfall
    Nightfall Posts: 10,083
    edited March 2017
    Holy.... that midwoofer looks like it's taken some dings and those screws... you might need hurricane nuts or Larry's rings. You'll find out.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Thank you all very much thank you all for the information these where actually my uncles garage speakers so they have taken quite a beating over the years I picked them up not to long ago he wanted smaller speakers I think these polk speakers are a diamond in the rough I can't wait to get the crossover upgraded and I'm sure they will sound awesome I'll take a picture of the crossover in the morning.
  • VSAT88
    VSAT88 Posts: 1,367
    Where are you located. I may have parts that will help. No charge.
  • Oldreliable7m
    Oldreliable7m Posts: 19
    edited March 2017
    I'm located in Aurora Colorado.
  • ken brydson
    ken brydson Posts: 9,049
    Posting you phone # isn't the best idea. If you have time to edit I'd take it out.
  • motorhead43026
    motorhead43026 Posts: 4,047
    Oh boy, time to make some prank phone calls.
  • Nightfall
    edited March 2017
    There's 10 pizzas on the way to your place.
    afterburnt wrote: »
  • vmaxer
    vmaxer Posts: 5,121
    Nightfall wrote: »
    25 now.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • lightman1
    lightman1 Posts: 10,797
    edited March 2017
    He needs a new Direct TV system, too.
    Plenty o' phone reps need his #.
  • Nightfall
    Male dancers will be there at 3PM for a bachelorette party.
    afterburnt wrote: »
  • Well the good news is the passive radiator seems to be in good condition. The tweeter and the mid woofers are easily available.
    The passives are harder to come by, so you may have dodged a bullet.
    Have fun!
    HT: Marantz NR-1603, Oppo 981, Def Tech SM55, SVS PB-1000
    BR: iPad Mini, Audio Engine A5+
    2C: Parasound ZDAC V.2, Sony DA80ES, Sony XDR-F1HD, SVS Prime Tower, JSE .6 Infinite Slope
    Office: MBAir, Focusrite Scarlett 2i2, JBL LSR-308
    Projects: Polk RTA12, Polk Monitor 7, Revox B225CD, BIC 3-TM
  • K_M
    K_M Posts: 1,631
    No air leakage around those tweeters.... ;)
  • codycatalist
    codycatalist Posts: 2,661
    Those look like a "fun" project.
  • Yes yes they do But there better than my sda-1c i got form a mechanic that had them in a garage
  • FestYboy
    FestYboy Posts: 3,861
    Have you gotten anywhere with it?
    It's been a year, hopefully the are positive results?
  • not quite yet ill get to them after my sda-1cs im going to use the old sl2000 tweeters from my sda-1cs and put them into the monitor 7s then im going to upgrade the crossover sense they might be damaged or upgrade the midbass and see how they sound after that
  • its kind of hard juggling car problems and the project that i know ill love doing
