Quick rear channel question
Just upgraded my front and center to the Polk signature series from the tseries. I haven't upgraded the rears, still using t15's. Would upgrading the rears be worth it, you think there would be a discernable difference upgrading the rears? Please and thanks in advance
  • honestaquarian
    honestaquarian Posts: 3,275
    Human hearing is geared towards what's in front of us and as the sounds go further to the sides and rear our hearing becomes less and less sensitive.
    If they are Polks then they have the same basic Polk sound. The only reason for going with the same series is if you REALLY want to match them in a sort of OCD way.
  • rpf65
    rpf65 Posts: 2,127
    I would hold off replacing the rears for a month or so. That will given your new speakers time to break in. Then you will be able to make a more informed decision. Rears are more for ambient sound, so best to upgrade other aspects of your system before blowing your whole budget replacing existing speakers.
  • patstock11
    Thanks guys. I kind of figured as much as far as ambient sound etc.
