Turntable motor repair
Hey, does anyone in the DFW area know of anyone that may be able to repair a stand alone turntable motor?
I have a motor that I got a while ago that needs some tlc. I believe it uses a Pabst motor.
Any would be massively appreciated.
  • halo
    halo Posts: 5,618
    If you're willing to pack it up and send it to Chicago, check out Anthony's Electronics Service
    txcoastal1 Posts: 13,519
    edited March 2017
    ftworthaudio.com/
    Give them a shout, even if they don't repair the motor maybe they can point you in right direction
  • hochpt21
    hochpt21 Posts: 5,423
    I had my turntable motor replaced by a TV repair shop. I'm not saying all TV repair shops would, but they may have the skill and knowledge.
    Wouldn't hurt to look into that if you didn't have other options.
    nooshinjohn Posts: 25,988
    I took my motor apart when I got my Triangleart and replaced it myself with the exact same motor. You might be able to do the same by taking it apart and using google to find the correct one by part number.
