Soliciting advice on packing an amp
agfrost
agfrost Posts: 2,469
Looks like I may be packing a B&K ST-202+ for shipping for a Polkie. Obviously want to ensure that it arrives safely.
It has no original packing materials. Imagining that I'll need to buy some hard foam sheeting, find or make boxes for double-boxing, but need as much good advice as you all can offer.
Thanks.
Jay
  • scubalab
    scubalab Posts: 3,105
    Get an electronics box from UHaul or Home Depot. I've had success using these double-wall boxes with a couple inches of styrofoam around the item - especially the corners. Depending on the size, you could also double box with a smaller bos inside the electronics box. I also use shrink wrap on the item for protection from scratches. Just sent some speakers I was selling across the country successfully.
  • voltz
    voltz Posts: 5,384
    have some foam in a big box in storage. sent you a PM.
  • MrBuhl
    MrBuhl Posts: 2,419
    IMO, double boxed, only way to go. Heavy foam around amp and in between. Leave no room for shifting or for the amp to gain momentum inside the packing.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
    EndersShadow Posts: 17,705
    Find your box with around 2" of space on all sides, throw some expanding foam from a can in a trash bag, let it start to fully expand and put the amp on top of it. Let the bottom/side harden. Do similar for the top.
    It's how my work gets all our equipment shipped.
    That way it's fairly form fitted to the object.
    I've also used foam and bubble wrap like @scubalab mentioned.
    For that amp the most important thing is to protect the corners of the rack handle section as if dropped on one of those corners it's gonna be a problem.
    Most important is also looking at the shipping requirements for the shipper you are using and making sure to meet or exceeds those should a claim need to be made. And pay for insurance and make sure the item is bought as a transaction and documented well as to what was bought.
  • agfrost
    Thanks to those who've replied. I'm reading and will read more if/as they roll in.
    Jay
  • MrBuhl
    MrBuhl Posts: 2,419
    ^^ LOL PFB ^^
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • agfrost
    DSkip wrote: »
    Wrap it in cellophane and off it goes!
    I thought the top plate was large/smooth enough that I could simply cover it with stamps and drop it in a mailbox...No?
    Jay
    agfrost wrote: »
    DSkip wrote: »
    Just make sure to fill up the internal amp area with packing peanuts.
  • agfrost
    Good call Dan. Styrofoam, or the biodegradable cornstarch ones?
    Jay
    Up the ante. Actual peanuts :smile:
  • gmcman
    gmcman Posts: 1,849
    Anything of value like this and that's heavy, I like to use 1/8" hardboard or possibly 1/4", lining the outer box, then use dense foam against the hardboard to surround the inner box, use bubble wrap to take up any gaps if needed. Hardboard is thin and cheap and offers fairly decent puncture resistance.
    The inner box if you don't have the original packing, I would wrap the amp in a garbage bag, then wrapped with bubble wrap, lining the inner box with styrofoam or more very dense foam.
    I always go over the entire outer box with clear tape, seams first. I don't trust anyone to not protect from the weather.
    To go an extra step, paint the outer box in white primer before taping, slightly less of a giveaway to prying eyes.
  • Willow
    Willow Posts: 11,233
    As long as the transaction has no contact with PFB you'll be fine.
    When Bob shipped my parasound, it was done very well. Amazing actually. Perhaps shoot him a pm
  • daddyjt
    daddyjt Posts: 3,087
    If at all possible, remove the rack handles/ears for shipping.
    Also, if the amp does not have a removable power cord, do not let its coiled up bundle rest at the back of the amp, specifically against the rcas or binding posts - ive seen both damaged from impact with a cord bundle - best to coil it under the amp, with foam or bubble wrap.
    ― Aleksandr Solzhenitsyn
    pitdogg2 Posts: 27,065
    scubalab wrote: »
    I would use pink or blue styro board if going this route its much more sturdy than beadboard.
    My.02
    I've also thought of the approach Dan mentioned just didn't have the nads to try it.
  • DaveHo
    DaveHo Posts: 3,583
    edited March 2017
    Get the white EPS foam, not blue board foam. Regular old white EPS foam will absorb shocks more effectively than the more sturdy kind.
    Your best bet is to go to the local home center & find a piece with some chunks missing. Usually, they will practically give it to you to get it gone since nobody who would want it for insulating will buy it. I just bought a 2' x 8' piece of EPS foam from Home Depot for $5 because a corner was broke off & it had been sitting.
    billbillw Posts: 7,566
    Personally, I hate the mess that the EPS/styro sheets make when you cut them and you need to make sure the amp is sealed in a plastic bag before rubbing agains the styro. Otherwise, the buyer will have lots of tiny pieces to retrieve from the vents, cracks, knobs, etc.
    If you have some of the expanded "pour and pack" type polyurethane foam that some shippers use, it will cut up with much less mess. I've recycled many of those to pack heavy items.
    I've also had success shipping heavy amps simply using correct size double box and lots of the large size bubble wrap. 3-4 layers minimum around the amp and taped tightly, double/triple the wrap in corners by folding over and taping. Boxes should be double-wall if possible. "Correct" box size means at least 3" oversize in each direction, but not so large as to cause shifting. Foam peanuts also work well to fill the void between the inner and outer box. Just make sure you have enough to pack tight and it won't shift.
    Overall, it just takes some care and caution.
  • daboyz
    daboyz Posts: 5,207
    I've got this kids. I've got everything he needs except maybe the box. :)
