Rubber stoppers for fxi5.
Hi
I picked up a set of used fxi5. They didn't come with those rubber stoppers / pads that go on the back of the speaker when you wall mount. Does anyone know where to get these? Emailed customer support a few weeks ago now and no answer yet, just a ticket number.
lsim705,lsim706c,lsif/x(4)+mc80(atmos)
rti6,csi5,fxi5
    F1nut Posts: 51,895
    The hardware stores sell all kinds of bumpers as do numerous online sources.
  • lightman1
    lightman1 Posts: 10,797
    Look for adhesive rubber, poly, silicone discs. Check for thickness to keep them from being too thick or thin once attached to the wall mounting.
    Furniture stoppers/discs can also be used and cut to size.
  • mantis
    mantis Posts: 17,554
    Home depot has a great selection for what you need.
    Dan
  • gurot1
    gurot1 Posts: 519
    Thanks. Anyone know which depth the spacer needs to be?
    rti6,csi5,fxi5
  • mikeyb128
    mikeyb128 Posts: 2,885
    Why don't you measure the rubber bumper on those nice lsifx I sent you? I believe it is similar design.
    2 channel:
    Theater:
  • gurot1
    gurot1 Posts: 519
    Lol, mikeyb128, I was thinking of doing exactly that
    rti6,csi5,fxi5
  • gurot1
    gurot1 Posts: 519
    So are you guys telling me there haven't been any mind blowing breakthroughs in rubber stopper technology? :p
    rti6,csi5,fxi5
  • mikeyb128
    They won't change your sound if that's what you mean. :smiley:
    2 channel:
    Theater:
    txcoastal1 Posts: 13,514
    mikeyb128 wrote: »
    Prove it :*
    pitdogg2 Posts: 27,181
    gurot1 wrote: »
    Bend over you tell me :p
  • gurot1
    gurot1 Posts: 519
    Won't it turn my 7.1 into atmos?!
    rti6,csi5,fxi5
  • mikeyb128
    txcoastal1 wrote: »
    mikeyb128 wrote: »
    Prove it :*
    Oh my god, I think I just comited my first troll.
    2 channel:
    Theater:
  • gurot1
    gurot1 Posts: 519
    Here is a picture of the fx500 vs the lsifx. The lsifx has a deeper stopper. hgyr4wbxx1x5.jpg
    The stoppers are pretty well as deep as the power port/mounting bracket
    rti6,csi5,fxi5
    edited March 2017
    Have you looked here? If they don't have it you may not need it :p
    http://www.essentracomponents.com/en-us
  • gurot1
    gurot1 Posts: 519
    Wow, they have a large inventory!
    rti6,csi5,fxi5
