speaker wire pins
Willow
Willow Posts: 11,224
are these to be used when you have speakers with clips ? or can they be used on binding posts ?
Post edited by Willow on
  • faster100
    faster100 Posts: 6,124
    edited October 2004
    Yes for spring clips, certainly you can use them in binding post. they will be a bit small and not the tightest fit, but inserted into the hole and tightened with the nut will work.. if thats all you have to work with.
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • Willow
    edited October 2004
    thanks. I have nanners on all mine but I have 12 new pins lying around and never really knew what they where for...til now
  • Tour2ma
    Tour2ma Posts: 10,177
    edited October 2004
    Best use is for holding a pair of olives together in a martini...
    More later,
    Tour...
    Vox Copuli
  • Willow
    edited October 2004
    Nah !! not big enough to hold the olives in my martini :D
  • scottnbnj
    scottnbnj Posts: 709
    edited October 2004
    i've used needle nose pliers to bend a curve on the end to fit into the binding post. the fit is snugger than straight pins and the lugs don't come loose as they sometimes do with straight pins.
