preamps
mhardy6647
mhardy6647 Posts: 35,337
edited February 2017 in 2 Channel Audio
Due to the kindness of a friend from MA, I got to play with a couple of nicer than average vacuum tube (kit built) preamps yesterday.
A tricked-out Bottlehead Foreplay:
32217139523_2ba58788a9_b.jpgDSC_7133 (3) by Mark Hardy, on Flickr
and a "Vacuum Tube Audio" SP14:
http://www.tubes4hifi.com/SP14.htm
32650125070_3866df6a74_b.jpgDSC_7135 (2) by Mark Hardy, on Flickr
They both sounded pretty good to me (us). The Foreplay seemed a bit more forward sounding but was otherwise very much in the running with the SP14 thingy.
  • muncybob
    muncybob Posts: 3,276
    Why left/right gain plus master volume control? Has a nice clean design.
    Yep, my name really is Bob.
    Just a way to manage gain, balance and easy adjustment of volume, I reckon.
    The three controls are all in the form of stepped attenuators. This particular example of this preamp, at least, is fairly seriously resourced.
  • motorhead43026
    motorhead43026 Posts: 4,047
    I like foreplay, never experienced bottlehead but I am game.
  • Those do look real nice. I need to stay away from anything with tubes. With my addictive personality I can see me being tube poor.
    I've been trying to spend some time upstairs.
    So far, the rhythm of my consulting biz shows a lag in the first couple of months of the year, then some acceleration to a nutso end of the year. This is the best time of the year to play inside, too -- garden season's not that far away.
  • halo
    halo Posts: 5,619
    I would love to try a bottlehead phono pre in my setup or a budgie tube phono pre - just to see what some tubes would bring to the vinyl side of the setup.
    careful what you wish for :)
    The 'entry level' Bottlehead phono preamps sound pretty good. The gain is a little limited, though. Maybe not a big problem for normal folks :) but in my system I have to crank things up pretty much to their limits if I want to listen "loud".
    This isn't horrific but it's a little bit of a disappointment.
    For the record, there are ahem two Bottlehead phono preamps here.
    One is a very early version of their original preamp kit (the Seduction). It is 'bare bones' (none of the Bottlehead 'upgrades' -- except it was retrofitted with their later, better - shielded, if memory serves - power transformer).
    32444831221_f9f335ba8f_b.jpgDSCN5316 by Mark Hardy, on Flickr
    33038931165_18a0cd0d68_b.jpgDSCN5315 (1) by Mark Hardy, on Flickr
    this is what it looks like below decks (with the original PT):
    33038907205_8f8e25c3a9_b.jpgP1020755 (1) by Mark Hardy, on Flickr
    and :) this is what it looks like with the retrofitted, Bottlehead-brand PT:
    32997135926_172f122769_b.jpgP1020763 (1) by Mark Hardy, on Flickr
    The other one is mrbiron's kit-built Reduction. :)
    Rather nicer in all respects (including execution of the build & finish!) than my Seduction
    25277999734_db5e0833e2_b.jpgDSC_2913 by Mark Hardy, on Flickr
    Both of these are two stage preamps using 6DJ8/6922 high-mu triodes and passive RIAA EQ.
  • Willow
    Willow Posts: 11,294
    Who doesn't like foreplay.....
