Marantz SR 5011 & MacBook
Kingkwas
Kingkwas Posts: 92
edited February 2017 in Going Digital
Best way to connect my Marantz SR 5011 to my MacBook?
Tried using USB 3.0 cable but it won't connect
Does AVR have a DAC? Was able to connect my iPhone & play music
AVR: Marantz SR 5011
L/ R: Polk Audio 703 LSiM (Bi Amp'd)
C: Polk Audio 255c - LS
R: Def Tech
Sub: PSW 505 (12 inch)
DVD: Oppo UDP 203
TV: 2016 Sony XBR 75X850D
  • Help please?!
    R: Def Tech
    DVD: Oppo UDP 203
  • Nightfall
    Nightfall Posts: 10,083
    You could do Audioquest Dragonfly and 1/8" to unbalanced RCA cable.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • rooftop59
    rooftop59 Posts: 8,120
    Just airplay man. Easy peasy.
    The AVR does indeed have a dac. Did you select the right audio output on your mac when you connected via USB?
    Game Room 5.1.4:
    Bedroom 2.1
  • DSkip wrote: »
    Still looking. I assume you connected a USB cable from the Macbook to the front USB port on the 5011. This won't work per page 59 of the manual. It will work with an ipad/iphone or an external hard drive - just not a computer.
    Generally, for a USB to work with a computer you need a USB-B type connection on the receiver.
    Thanks for help. Yes. I've tried connecting MacBook Air to Marantz via USB 3.0 cable. Did not work. Ordered a optical adapter and will try to connect that way.
    Will keep you posted. Thanks again.
    R: Def Tech
    DVD: Oppo UDP 203
  • rooftop59 wrote: »
    AirPlay will compress signal. Trying to play Tidal "Master" albums.
    https://support.tidal.com/hc/en-us/articles/115000397069-TIDAL-MASTERS
    R: Def Tech
    DVD: Oppo UDP 203
  • Nightfall
    If you want to play MQA you're going to need a Meridian Explorer DAC.
    afterburnt wrote: »
    Kingkwas wrote: »
    rooftop59 wrote: »
    We have another thread going on Tidal and the MQA needed for Tidal and the Master albums. You won't get that by plugging into the Marantz alone.
