preamps
mhardy6647
Due to the kindness of a friend from MA, I got to play with a couple of nicer than average vacuum tube (kit built) preamps yesterday.
A tricked-out Bottlehead Foreplay:
DSC_7133 (3) by Mark Hardy, on Flickr
and a "Vacuum Tube Audio" SP14:
http://www.tubes4hifi.com/SP14.htm
DSC_7135 (2) by Mark Hardy, on Flickr
They both sounded pretty good to me (us). The Foreplay seemed a bit more forward sounding but was otherwise very much in the running with the SP14 thingy.
DSC_7133 (3) by Mark Hardy, on Flickrand a "Vacuum Tube Audio" SP14:
DSC_7135 (2) by Mark Hardy, on FlickrThey both sounded pretty good to me (us). The Foreplay seemed a bit more forward sounding but was otherwise very much in the running with the SP14 thingy.
Why left/right gain plus master volume control? Has a nice clean design.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Just a way to manage gain, balance and easy adjustment of volume, I reckon.
The three controls are all in the form of stepped attenuators. This particular example of this preamp, at least, is fairly seriously resourced.
I like foreplay, never experienced bottlehead but I am game.Patriotism is the last refuge of a scoundrel…….Samuel Johnson
– Kevin Alfred Strom -
Those do look real nice. I need to stay away from anything with tubes. With my addictive personality I can see me being tube poor.Patriotism is the last refuge of a scoundrel…….Samuel Johnson
I've been trying to spend some time upstairs.
So far, the rhythm of my consulting biz shows a lag in the first couple of months of the year, then some acceleration to a nutso end of the year. This is the best time of the year to play inside, too -- garden season's not that far away.
I would love to try a bottlehead phono pre in my setup or a budgie tube phono pre - just to see what some tubes would bring to the vinyl side of the setup.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
careful what you wish for
The 'entry level' Bottlehead phono preamps sound pretty good. The gain is a little limited, though. Maybe not a big problem for normal folks
but in my system I have to crank things up pretty much to their limits if I want to listen "loud".
This isn't horrific but it's a little bit of a disappointment.
For the record, there are ahem two Bottlehead phono preamps here.
One is a very early version of their original preamp kit (the Seduction). It is 'bare bones' (none of the Bottlehead 'upgrades' -- except it was retrofitted with their later, better - shielded, if memory serves - power transformer).
DSCN5316 by Mark Hardy, on Flickr
DSCN5315 (1) by Mark Hardy, on Flickr
this is what it looks like below decks (with the original PT):
P1020755 (1) by Mark Hardy, on Flickr
and
this is what it looks like with the retrofitted, Bottlehead-brand PT:
P1020763 (1) by Mark Hardy, on Flickr
The other one is mrbiron's kit-built Reduction.
Rather nicer in all respects (including execution of the build & finish!) than my Seduction
DSC_2913 by Mark Hardy, on Flickr
Both of these are two stage preamps using 6DJ8/6922 high-mu triodes and passive RIAA EQ.
motorhead43026 wrote: »I like foreplay, never experienced bottlehead but I am game.
Who doesn't like foreplay.....
