SENCORE TC28 "THE HYBRIDER" Vacuum TUBE TRANSISTOR TESTER
For sale is a used and working SENCORE TC28 "THE HYBRIDER" Vacuum TUBE TRANSISTOR TESTER I tested a few tubes on this to be sure it worked and it seems to work fine, I did not test any transistors but no reason to assume that it does not work for them too.
I have enough tube testers as it is and this one just sits around collecting dust and taking up space it would make a great tester for someone that needs to check out a few tubes every so often and it appears to test most commonly used types and is very simple to use.
$125.00 + shipping
It is a heavy little beast so likely shipping will be a fair amount.
Regards Snow
    txcoastal1 Posts: 13,513
  • WagnerRC
    WagnerRC Posts: 2,205
    Sold and I can add this to the tubes we dealt with today. Thank you
    WagnerRC wrote: »
    Glad it worked out for you guys
    Thumbs up
  • snow
    snow Posts: 4,358
    Your welcome I will send you a total when I get it packed up.
    Regards sNOW
  • snow
    snow Posts: 4,358
    txcoastal1 wrote: »
    WagnerRC wrote: »
    Thumbs up
    Thanks for the assist :)
    Regards Snow
    mhardy6647 Posts: 35,046
    edited February 2017
    Apropos of nothing: I've never seen this particular Sencore before -- cool & interesting piece from the 'transitional' era. Sencore made excellent "service-person" grade test equipment.
    WagnerRC, it should be a good, rugged, dependable emissions-type (tube) tester. Presuming it has the heritage of Sencore's Mighty-Mite testers, it should have excellent sensitivity to test grid leakage.
  • snow
    snow Posts: 4,358
    Hey Mark I have something you may be interested in.
    Regards Snow
  • snow
    snow Posts: 4,358
    Hi Mark per your request here are a couple of pics of the inside.
    Regards Snow
    Thank you very much, sir!
