Wow speaker wire does make a difference.
Just got my order in from Blue Jeans, terminated them with some locking banana plugs then a/b them vs my old monster wire.
Granted I know monster cable is crap but I couldn't have imagined the difference in bass these cables provided. Most likely helped that I went from 16g to 10 but still, loving these new cables. I've never seen my passive dance so much!
Now to wait for my rd0s to come in, ordered Friday so hopefully soon.
  • lightman1
    lightman1 Posts: 10,778
  • codycatalist
    Haha of course you would be the first to comment Russ. :D
    You LOVE cable discussions or is that refuting them?
  • kevhed72
    kevhed72 Posts: 4,967
    Good luck threading the 10awg wire into the locking nanner plugs. . I hope your a patient person ☺️
  • lightman1
    I'm a sucker for good cables and a cute redheads, Cody.....guilty as charged, Your Honor. o:)
  • codycatalist
    kevhed72 wrote: »
    It was a chore that's a fact. I ended up ordering a pair too short of what I needed from BJC so I picked up some GLS audio "gen 4" plugs. Nice and heavy, don't look too bad to boot.
  • codycatalist
    codycatalist Posts: 2,662
    edited February 2017
    lightman1 wrote: »
    I think you made a mistake. You put o:) I'm pretty sure it was meant to be >:) you devil you.
  • gp4jesus
    gp4jesus Posts: 1,969
    16 ga to 10 ga?!
    Monster to Blue Jeans?!
    Mo' bigga, mo' betta!!
    Passive?
    Now to wait for my rd0s to come in...
    rd0s?
    Enjoy! Tony
    Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
  • [Deleted User]
    [Deleted User] Posts: 10,716
    Thats it, I'm going into business.
    Here is my boutique section
  • codycatalist
    gp4jesus wrote: »
    16 ga to 10 ga?!
    Passive?
    rd0s?
    Enjoy! Tony
    Passive radiator, rd0194 tweeters. :)
  • codycatalist
    I'll trade you my blue jean cables!
  • [Deleted User]
    [Deleted User] Posts: 342
    More copper *generally* equates to better bass in speaker cables, hence in lower price cables you can get a nice boost using 10g cable. Though if you look at my Jorma Statement sc's (see below), the twin runs of cable are quite thin, yet they are well balanced top to bottom which is counter intuitive. Sure, Siltech Royal Sig or Crown series, or the top level PAD cables have more bass, but that isn't always a good thing, particularly if your speakers already have good output and are reasonably efficient.
  • Joey_V
    Joey_V Posts: 8,526
    Bodhi wrote: »
    I like your cables and your carpet is fancy.
    Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
  • codycatalist
    They are purdy
  • Nightfall
    Nightfall Posts: 10,073
    The $1,200 MIT StyleLine SL12's don't use massive gauge wire either, about the same as the Jorma in that picture.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • codycatalist
    Nightfall wrote: »
    I had to choose between 12 and 10 gauge and just shot on the 10. I conceal all my wires so they aren't an issue with size, they also fit perfectly in my bananas so why not.
  • Joey_V
    Joey_V Posts: 8,526
    I like that my wel has some heft but then it's heavy and that has its disadvantages.
  • codycatalist
    Joey_V wrote: »
    Just curious what are the disadvantages You See?
  • Joey_V
    Joey_V Posts: 8,526
    Joey_V wrote: »
    Heavy and it puts stress on the binding posts. If I had bookshelves it's over for the speaker... That thing is tipping over
    But I can overlook that because the wel is daddy's little girl...
    ... Oh wait that's Emma...
  • Nightfall
    How much do the Wels weigh? Enough to tip over a stand and 25+ pound bookie? That's insane.
    Can your B&W stands be mass loaded?
    afterburnt wrote: »
  • [Deleted User]
    Nightfall wrote: »
    The other advantage is the cables are very easy to work with, which given the space restrictions behind my racks, is a godsend.
