Rear speakers....which ones
GaryZ06
GaryZ06 Posts: 317
edited October 2004 in Speakers
Hey guys nice site you have here....I would like to ask for your opinion.I just recently purchased Polk RTi12's for the front and a CSi5 for the center...both in cherry wood.I will be purchasing a Velodyne sub very soon.My question is what Polk speaker should I use for the surround speaker? I am confused to either use a regular speaker or a Di/Bi polar speaker.Here is a picture of my set up as of now.On the right side just above the speaker you can see a taped outline....I am having it cut out for my gear to be flush mounted.Thanks in advance.
Panasonic 50" Plasma + Pioneer 6010
Toshiba XA2 HD-DVD
Panasonic BD30 Blu-Ray
Pioneer 1014
Polk RTi12 (front)...Polk CSi5 (center)
Polk RTi4 (rear)...Velodyne DLS 5000-R Sub
3 Outlaw M-200 Amps
Post edited by GaryZ06 on
  • Willow
    Willow Posts: 11,226
    edited October 2004
    Welcome and nice set up it depennds on your rear set up is your seating against the wall ??
  • GaryZ06
    GaryZ06 Posts: 317
    edited October 2004
    Thanks and yes my couch is against a mirrored wall.
    Toshiba XA2 HD-DVD
    Pioneer 1014
    3 Outlaw M-200 Amps
  • Willow
    edited October 2004
    what about $$ flow the best bet would be more towers like the 8's but if you like the sound of bi-dipole and not direct the fix3 would be a good choice depending on the set up of the rear wall. If not the 6's or the 4's on stands or on wall
  • GaryZ06
    GaryZ06 Posts: 317
    edited October 2004
    I'd rather go with speakers on stands.I really don't know....what I mean that I never have heard bi-dipole speakers....that is why the confusion.Is there an advantage or difference over a direct speaker.Thanks again.....my rear wall where the couch rest on is fully mirrored.
    Toshiba XA2 HD-DVD
    Pioneer 1014
    3 Outlaw M-200 Amps
  • Willow
    edited October 2004
    for the fx's you may have to build your own stands the base a weird shape, the 6's are very large bookshelves the 4's might be nice size. have you read the info on the polk site regarding bi-dipoles ? you can order their hometheatre set guide for free and it is full of info .
    http://www.polkaudio.com/home/library/hthandbook.php
  • GaryZ06
    GaryZ06 Posts: 317
    edited October 2004
    Building stands is not a problem....No I have not read any info yet on them but I am having them mail me the handbook.Off hand just by looking at their design I would think the bi-dipoles have more of a reflected sound......So far I am still confused to which type of rears to go with....
    Toshiba XA2 HD-DVD
    Pioneer 1014
    3 Outlaw M-200 Amps
  • Willow
    edited October 2004
    I myself would like to get bi-dipoles but my room set up would not be good for that type of speaker (we have a wall beside the couch that would reflect to much sound) will you run a 5.1 6.1 or 7.1 system ?
    the fx are more of a discrete room filling while I find the directs more in your face. Maybe someone who owns some could chime in here and help out
  • GaryZ06
    GaryZ06 Posts: 317
    edited October 2004
    I will be running either a 5.1 or 6.1 don't really know yet.Thanks for your valuable help.
    Toshiba XA2 HD-DVD
    Pioneer 1014
    3 Outlaw M-200 Amps
  • MikeCamp
    MikeCamp Posts: 12
    edited October 2004
    IMO, dipole/bipole speakers are not very good for music. If you plan on only using the system as a theater system then its fine. I listen to alot of music and don't want the sound bouncing around. Monopole is the way to go if you listen to a lot of music. IMO
    Hope this helps.
    Oh, and to answer your question = RTi4s would be my choice :)
    Yamaha RXV3300
    Polk LSI series - 15,C, and FX
    Infocus 4805
    Emotiva XPA-5 power amp
  • DesertPilot
    DesertPilot Posts: 57
    edited October 2004
    Hi,
    My choice was to use RTi6 all around (5.1 system). If you ever plan on listening to DVD-Audio or SACD, you'll be glad you did. I have a few now and WHEW...what great sound from literally everywhere.
    Marcus
    LSi9 + LSiC + LSiFx
    dual PSW 505
    Integra DHC 80.2 Pre-Amp
    Outlaw 755 Amp
    OPPO BDP-93 universal player
    BENQ W6000 Projector
    Da-Lite120 inch diag screen.
    BlueJeans Cables all around.
  • Toxis
    Toxis Posts: 5,116
    edited October 2004
    Depends on your room. I love the Bipole speakers so I'll recommend FXi5's personally.
