Magnifi one flashing lights
Every 5 seconds, four white lights flash on my Magnifi One.
I'm pretty sure this just started after I had to disconnect the system completely to paint the room. After reconnecting, I had to go through the setup to link the subwoofer and to re-teach the Polk to recognize my TV's remote.
Everything is working fine again, but I'm worried about the four flashing lights. How can I fix this? I tried turning the Polk off and on, but this did not stop the flashing.
Best Answer
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Answer ✓
    A suggestion and a question from Polk CS:
    "The first thing I would try is to reset the bar by unplugging it from power for 1 minute and then plugging it back in.
    Do you know if it still plays the TV when those lights are blinking?"
    Ken
Answers
