Center channels as surrounds
Early B.
Early B. Posts: 7,900
edited October 2004 in Speakers
Anyone ever tried using center channel speakers as surrounds? Just curious.
"God grooves with tubes."
Post edited by Early B. on
  • EricH
    EricH Posts: 140
    edited October 2004
    I'm using CSi30's for side, as well as back surrounds. They have a shallow depth (6 1/2") which is great for wall mounting. Make sure that you give the ports enough room to breathe. I also had to drill holes in the back for mounts.
  • Early B.
    edited October 2004
    Cool. How do your Csi30's compare to the "standard" setup such as using the RTi28's, 38's or Fxi30's?
  • EricH
    EricH Posts: 140
    edited October 2004
    Another thing about the 30's, due to their lack of height, they tuck up near the ceiling really nice.
    I actually have used 28's, 38's, and the CSi30's for surrounds. They're much better than the 28's in think. Bigger sound due to having two 5 1/4" drivers. There was a 3 month gap between taking down the 38's, and putting up the CSi30's due to a room addition, but they seem fairly close. The 38's might go a little lower, but unless you're running them on large it won't matter.
    I have been experimenting on setting my surrounds on Large, and they sound really good. I think that anytime I can keep the sound coming out of the intended speaker, the better the surround experience. (Without distortion of course :-)
  • Early B.
    edited October 2004
    Cool. Thanks. Now if I can find a couple of Csi30's at a knockout price, I'd consider replacing my RTi28's as surrounds with them.
