Center channels as surrounds
Anyone ever tried using center channel speakers as surrounds? Just curious.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
I'm using CSi30's for side, as well as back surrounds. They have a shallow depth (6 1/2") which is great for wall mounting. Make sure that you give the ports enough room to breathe. I also had to drill holes in the back for mounts.
Cool. How do your Csi30's compare to the "standard" setup such as using the RTi28's, 38's or Fxi30's?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Another thing about the 30's, due to their lack of height, they tuck up near the ceiling really nice.
I actually have used 28's, 38's, and the CSi30's for surrounds. They're much better than the 28's in think. Bigger sound due to having two 5 1/4" drivers. There was a 3 month gap between taking down the 38's, and putting up the CSi30's due to a room addition, but they seem fairly close. The 38's might go a little lower, but unless you're running them on large it won't matter.
I have been experimenting on setting my surrounds on Large, and they sound really good. I think that anytime I can keep the sound coming out of the intended speaker, the better the surround experience. (Without distortion of course :-) -
Cool. Thanks. Now if I can find a couple of Csi30's at a knockout price, I'd consider replacing my RTi28's as surrounds with them.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
