Fiddling about with the pizzas of licorice
mhardy6647
mhardy6647 Posts: 35,156
edited January 2017 in 2 Channel Audio
OK, that sounds really tawdry, sorry :blush:
Let me try again. Trying to pick a good tt/cartridge combination for phono preamp comparisons.
Don't really want to use the DL-103 as it would necessitate adding a SUT to most of the preamps for adequate gain.
I am - it may be recalled - really lazy.
There's a Pioneer PL-12D in the basement with a Shure M97xe on it. Grabbed the headshell & cartridge, and stuck it on a Technics SL-1350 (for which I only have the multi-disc spindle!), balanced and set up and gave a listen via mrbiron's Reduction preamp.
The M97xe gets so much bad press -- but I like the way it sounds. Mellow, I think would be a fair way to describe it. Unquestionably musical, though,I'd say. Pleasant.
Very pleasant.
32452265331_9689656dcf_b.jpgDSC_6946 (2) by Mark Hardy, on Flickr
32452278551_c4d7266d6b_b.jpgDSC_6949 (2) by Mark Hardy, on Flickr
I tried the b&o TX-2, which has a b&o MMC-4 MI cartridge on it. A nice record playing "system", but sonically kind of lifeless. Not bad, but not "involving"; doesn't suck me in.
25277999734_db5e0833e2_b.jpgDSC_2913 by Mark Hardy, on Flickr
(earlier photo of the pairing)
I also have a nice ADC P-mount cartridge (don't remember the model offhand, but not BOTL) which sits upon an almost laughable "Fisher" branded belt-drive plastic tt from the late 80s or so. Almost laughable. The cartridge sounds quite nice -- and the arm and table don't really keep it from sounding good. I am sure it might sound better on a better platform -- but really not bad. It's also incredibly intolerant of record warps. It can track them OK, but the stylus doesn't raise up high enough to clear much of a warp when cueing!
25609935380_ff26cd8676_b.jpgDSC_2912 by Mark Hardy, on Flickr
Stay tuned for further developments.
  • motorhead43026
    motorhead43026 Posts: 4,017
    edited January 2017
    I have the exact same TT the SL-1350 fitted with the M97e, and I like the combo.
    Post edited by motorhead43026 on
    – Kevin Alfred Strom
    The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm.
  • mrbiron
    mrbiron Posts: 5,721
    Woohoo.....I know that preamp!
    I have the same inexpensive cart on my turntable as well.
    Stock tubes?
    No, I popped a pair of Dutch-made RCA 6DJ8s in. I think they sound better than the tubes that were in it -- but it's been so long, at some point I need to back substitute & see.
    I was ahem gonna pass the "RCA" tubes along when the preamp goes home -- it probably doesn't remember its "home" any more.
  • halo
    halo Posts: 5,616
    That is simply not possible as vinyl is labour intensive, albeit a labor of love ;)
    Naaah, it's more like obsession ;)
    You'll see...
    edited February 2017
    continuing the assessment of hardware here :)
    Last night's/today's volunteer: A Philips AF777 that happens to have a Microacoustics QDC-1e cartridge on it. The MA cartridges were rather strange birds -- they're "low output" (relatively speaking) ceramic cartridges that do require equalization.
    Ceramic cartridges, many of you will know (maybe even remember!) were widespread in massmarket "hifi" record changers, all-in-ones, and consoles. They have something of a bad reputation (somewhat undeserved) as record-gougers.
    Ceramics of that ilk had a "self-equalized" ca. 1V RMS output that could directly drive an amplifier (i.e., no MM preamp/RIAA equalizer required) -- it was perfectly capable to make a "hifi stereo" record player amplifier that used only two tubes (e.g., two 60FX5 power amplifier tubes) and preamp, equalization, driver/voltage amp stage, nor any power transformer! (Kids, don't try this at home).
    Over the years, there have been occasional attempts at producing hifi ceramic (piezoelectric) cartridges. No less than the likes of Grado and Electrovoice, e.g., have produced ceramic cartridges designed to compete with MM/MI cartridges.
    Microacoustics was one of the last (though not, IIRC, the last) to do so. Their cartridges have an output of a few mV (like most MM or MI cartridges) and, amusingly enough, an on-board "microcircuit" to de-equalize the signal so that the cartridge output could be used to drive a standard MM phono preamp!
    Opinions on these cartridges were decidedly mixed, so I thought it would be fun to try this setup (which I bought at the Harvard, MA townwide fleamarket many years ago) to see how it sounds.
    32547188461_abe8ed978c_b.jpgDSC_6964 (2) by Mark Hardy, on Flickr
    31857019143_e5d8b2bb08_b.jpgDSC_6962 (2) by Mark Hardy, on Flickr
    31859000453_07a279f7f7_b.jpgMA cart info 1977 by Mark Hardy, on Flickr
    It's interesting to read about these cartridges. There's a certain amount of intrigue around their claimed vs. actual performance. You can get an inkling of that in the footnote of this 1974 brochure capture (the document's available at vinylengine).
    32549209101_d9d8177e93_b.jpgMA QDC specs 1974 by Mark Hardy, on Flickr
    How does it sound, I hear you ask :)
    Well, it's -- interesting.
    I cannot vouch for the condition of the stylus on this one, nor the accuracy of the setup nor how happy it is driving the phono preamp currently hooked to it (mrbiron's Bottlehead Reduction, equipped with a couple of RCA-branded, Dutch-made 6DJ8s), but I can comment on how it sounds.
    It sounds very warm. Bass is full but kind of soft, for lack of a better word. Highs seem rolled off but not mistracked.
    Not too interesting so far, right?
    What's interesting is the midrange; in particular the vocals. The vocals are superb. Clear, immediate and natural. Borderline stunning. I didn't really notice anything else about the midrange that was impressive (though I've only listened to a few tracks so far). But I thought the cartridge's performance on vocals was noteworthy.
    Pretty crusty.
