High power amp recommendations for SDA-SRS (blade/blade)
sbb2112
I am looking to gain some headroom from where I am. Trey is just about done with the new crossovers and I've searched and found a couple threads on the subject but nothing recent. I have a Mac now at 300 wpc but was looking for maybe 450+ in a common ground amp. I am told that a Krell Duo 300 would fit the bill but was curious if anybody had suggestions. Have not heard the Krell but there are a couple on Audiogon.
Main System
Marantz AV8802A PrePro
Marantz MM7025 Amp rear surrounds
McIntosh MC7205 Amp center, ceiling and mid surrounds
McIntosh MC300 Amp front mains
Oppo 203 Bluray
Polk SDA-SRS with VR3 monastery crossovers
Polk FX1000 Mid surrounds
Klipsch RP-440C Center channel
Klipsch RP-15M Rear surrounds
SVS prime elevation ceiling surrounds
Rythmik F15HP sub
Samsung 8500 curved screen 65" LED 4K
Mac Mini Server
Office System
Musical Fidelity M6s dac/preamp
Oppo 103D Bluray
Polk SDA-SRS 2
Parasound HCA-1500A
Polk PSW 650 sub
Microrendu
Roku Ultra
Mac Mini Server
Oppo 203 Bluray
Rythmik F15HP sub
Mac Mini Server
Office System
Oppo 103D Bluray
Polk SDA-SRS 2
Parasound HCA-1500A
Polk PSW 650 sub
Microrendu
Roku Ultra
Mac Mini Server
The McIntosh will provide more than enough power. SDA's are an easy load to drive contrary to popular opinion.SDA SRS 2.3TL's
SDA 2B TL's -
Bladed original SRS's are 4 ohm correct? So is the Mac 300@ 4ohm?
The mac has 3 sets of taps. 8 ohm,4 and 2 ohm. The output rating is the same on all 3 i am on the 4 ohm taps and don't activate the power guard lights but it seems that the output noses over when i get close to the rated output so it may be starting to kick in. The issue is with music that has a lot of range, Pretty noticeable. Maybe the crossover upgrade will be a difference.Main System
Oppo 203 Bluray
Rythmik F15HP sub
Mac Mini Server
Office System
Oppo 103D Bluray
Polk SDA-SRS 2
Parasound HCA-1500A
Polk PSW 650 sub
Microrendu
Roku Ultra
Mac Mini Server -
Very, very different sound signature between those two brands.Political Correctness'.........defined
President of Club Polk -
Tough to get to lay ears on a Krell in my area. It was suggested to me by a dealer near a friend. My buddy told him what I was interested in and he called me. He is 2K miles from here so not really a short tripMain System
Oppo 203 Bluray
Rythmik F15HP sub
Mac Mini Server
Office System
Oppo 103D Bluray
Polk SDA-SRS 2
Parasound HCA-1500A
Polk PSW 650 sub
Microrendu
Roku Ultra
Mac Mini Server -
The difference between 300 watts and 450 watts is about one-and-a-half dBW.I have a Mac now at 300 wpc but was looking for maybe 450+ in a common ground amp.
If you already have 300 watts into 4 ohms, and that isn't enough, I'd think you'd better be looking at 600+ (3+ dBW) into 4-ohms, to get a reasonable improvement. More would be better.
The question I'd be asking is "Is my amp working properly" because 300 watts seems like a lot of power. How big is your room? "Lively" or "dead"?
Nothing wrong with that amps power. Look elsewhere in your system but first wait until you get the speakers crossovers burned in before making assessments. Your problem can very well be the room, cabling, your source component, which all have an affect on the sound your hearing.HT SYSTEM-
lsi 9's -
I found a post here where a pair of Bryston 7B amps were strapped together with the SDA-SRS's with no report of problems. Those are 600W amps. That might be an option. The Krell Duo 300 is rated at 540W at 4 ohms. So, yes the 450 wouldn't be much better over the 300. Trey says my crossovers will ship on Monday. The room is fairly well treated, carpet, 2 bass traps on sidewalls, 18X16X9'. Belden 5T00UP Speaker Cable, GLS Audio XLR interconnects, Tributaries T200 power conditioners.Main System
Oppo 203 Bluray
Rythmik F15HP sub
Mac Mini Server
Office System
Oppo 103D Bluray
Polk SDA-SRS 2
Parasound HCA-1500A
Polk PSW 650 sub
Microrendu
Roku Ultra
Mac Mini Server -
Again, you have plenty of power on tap for those speakers with the Mac. Could also be you just are not tickled with the Mac's presentation. Don't just assume throwing watts at those speakers will wake them up.
Also, your cabling needs work. MIT, Acoustic zen, Wireworld, Harmonic Technology, Audioquest, Kimber....some of the better cabling companies to search for on the used markets.
Wait until you get the crossovers installed and burned in before making judgements. What are you using for a source for your music ?HT SYSTEM-
lsi 9's -
Using the Oppo-103d with a usb HD with all the files in flac format. Fed thru the Marantz. I should see or be able to tell a lot about things in the next couple weeks.
Main System
Oppo 203 Bluray
Rythmik F15HP sub
Mac Mini Server
Office System
Oppo 103D Bluray
Polk SDA-SRS 2
Parasound HCA-1500A
Polk PSW 650 sub
Microrendu
Roku Ultra
Mac Mini Server -
I have been wrestling with all the possibilities of how to make the old girls sing again and really appreciate the help. The many thoughts really save me from a lot of missteps and I guess maybe help others from the same. I'll keep posting my progressMain System
Oppo 203 Bluray
Rythmik F15HP sub
Mac Mini Server
Office System
Oppo 103D Bluray
Polk SDA-SRS 2
Parasound HCA-1500A
Polk PSW 650 sub
Microrendu
Roku Ultra
Mac Mini Server -
If you look carefully, the commentators are preaching patience.
I'd advise you to embrace & heed that advise.
I've got lots of patience, more than funds. There is good advise here, planning for where to head next. Looks like cables may be something to budget for next more than a bigger amp. Maybe later.Main System
Oppo 203 Bluray
Rythmik F15HP sub
Mac Mini Server
Office System
Oppo 103D Bluray
Polk SDA-SRS 2
Parasound HCA-1500A
Polk PSW 650 sub
Microrendu
Roku Ultra
Mac Mini Server -
Make sure you test all the drivers too to make sure they are working properly. Last thing you need is to find out a tweeter or 2 have gone south or a mid is frozen. Hopefully the poly switches too were removed.HT SYSTEM-
lsi 9's -
If you get to the point that you want more power, you might want to look at this Perreaux vintage amp, which has been on eBay for a few weeks, now.
http://www.ebay.com/itm/Perreaux-PMF-5150B-Power-Amp-2-CH-500-Watts-per-Channel-Mint-Cond-120v-or-220v-/222275240918?hash=item33c0a303d6:g:Lf8AAOSwPCVX-nBh
I use Perreaux electronics -- vintage and new -- with my SDA 1Cs and SDA SRS 1.2tls -- both with crossovers modified by Trey.
The amp is rated at 1000 watts RMS into 4 ohms, and from personal experience I can say that Perreaux amps from the 1980s are conservatively rated.
I think the Polks and Perreaux amps/preamps match up well, but of course, that is matter of individual taste. The amp on eBay is the one with which I first auditioned SDA SRSs and my memories of the sound were what drove me back to the SRSs many years later.
The eBay seller claims that it is in "mint" condition, which it is not -- the power switch (a rare weak point in vintage Perreaux amps) and the plug on the power cord have been replaced.
BTW --I have no affiliation with the seller.Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
Well I am awaiting the new crossovers and have measured the output from the amp with a voltmeter. Everything seems appropriate there. I am not deaf. Everything there OK too. I found a chart for estimating SPL and everything there is off by about 15db. I have the gear at the opposite end of the room and the speakers at the other end. The cables are 40 ft. long. I can either move everything and have short cables, move the 2 channel amp and have short speaker cables and long XLR cables or leave as is.Main System
Oppo 203 Bluray
Rythmik F15HP sub
Mac Mini Server
Office System
Oppo 103D Bluray
Polk SDA-SRS 2
Parasound HCA-1500A
Polk PSW 650 sub
Microrendu
Roku Ultra
Mac Mini Server -
If your pulling the drivers and everything out in the very near future, i highly recommend installing Larry's rings at the same time if you haven't all ready!
Larry has just put a warning order out around a week ago regarding his rings and i can honestly say you won't regret it.
