LSiM 703 Speaker Stands
rochesterboy
in Speakers
A nice selection.
http://www.liedtke-metalldesign.eu/epages/64011114.mobile/de_DE/?ObjectPath=/Shops/64011114/Categories/"Liedtke-Metalldesign Lautsprecherständer"Political Correctness'.........defined
President of Club Polk -
these will work for the budget minded...
https://www.amazon.com/Ignite-Pro-Near-Field-Monitor-Adjustable/dp/B01BNE160O
oops! not these but the 31 inch version -
rednedtugent wrote: »these will work for the budget minded...
I was going to say... Do you not sit down when listening?Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
You too.
How tall are you freaks that you need a 44" stand?Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
You too.
Maybe use them for HT rear channels that need to be elevated over a couch2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Skylan - I purchased a pair (Sky-28D) for my 703's this spring from Noel. Very well made.
http://www.skylanstands.com/stands.htm -
Thank you so much all for all the suggestions. Much appreciated.
txcoastal1 wrote: »
You too.
HmmmMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
You too.
6'12" -
The transdeco 24" stands from Amazon work beautifully for 703's too at a modest price.2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
Good stands aren't cheap and cheap stands aren't good.Political Correctness'.........defined
That's an extremely generalized statement there sir.2 Channel in my home attic/bar/man cave
I bought these, but returned them. They were missing the top plates. Not too impressed with how they looked, either.
https://www.amazon.com/gp/product/B004STEH08/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
Ended up with these. Very well built. A good compromise of price/quality. I did not feel the need to fill with sand.
https://www.amazon.com/gp/product/B00CQCIRTG/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1 -
I got the same ones, great stands, if you are on a real budget the Daytons I mentioned earlier in this post are surprisingly well made. here is a pic of both.
Ended up in purchasing this in RED color. Hopefully it will match with my Cherry hardwood floor.
Thanks for all the suggestions:) -
I'm speechlessPolitical Correctness'.........defined
+1
Yuck. -
Sorry wrong link. This is the one I bought in red.
https://www.amazon.com/gp/product/B005QM6UE2/ref=ox_sc_act_title_11?ie=UTF8&smid=ATVPDKIKX0DER&th=1 -
Which height did you get? 36" or 44" will both be too tall for the 703's. The 24" transdeco would have been a much better height option and has plenty of positive reviews on here2 Channel in my home attic/bar/man cave
Too late. Don't bum him out.
stangman67 wrote: »Which height did you get? 36" or 44" will both be too tall for the 703's. The 24" transdeco would have been a much better height option and has plenty of positive reviews on here
36. I need that the height for my sitting position. If not, will return it and will look into 24" transdeco or something else. Thanks for all the suggestions. -
I see. Good luck!2 Channel in my home attic/bar/man cave
The height would honestly depend on your listening height/seat. I would look at the height of the LSi705, estimate tweeter and midrange height and see what that translates to in terms of a stand.
From my experience, to prop a 20" tall bookshelf on a 36" stand is tall.
Unless you listening position is atop a bar stool, 36" is too high. That will put the tweeter around 46" which is just slightly under the total height of an LsiM705.
Exactly. Or if you are nearfield on a computer chair.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
I thought of using 703 as HT fronts or HT sorrounds in 7.1 setup. 703 with this stand will be at 51", little taller than 705. So I thought it would work. I like the look as well
rochesterboy wrote: »I thought of using 703 as HT fronts or HT sorrounds in 7.1 setup. 703 with this stand will be at 51", little taller than 705. So I thought it would work. I like the look as well
Fine for surrounds, but too tall for mains. But if looks are more important than sound, more power to you.
Rock on.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
