RT 2000i (need crossover) I know...good luck right??
tophatjohnny
after buying the top speaker, (which was blown too) I called and spoke with a tech here @ polk and was advised to send in the amp for repair. In disassembling the cab, I decided to remove the foam in the top half and there was the meanie..bold and fried....the cross over in the top section is blown to heck. Praying someone will be able to help fix or replace this part?? Any help will be appreciated. Fingers crossed.
Post edited by tophatjohnny on
Dang...:eek:
Good luck!
Dang...:eek:
Good luck!
yeah, I know, I think I said that in the heading!!:biggrin: maybe someone here will be able to help?? Man???????"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
Crap!:eek:
Trey (VR3) or F1nut can do them for you, if they have the time.
But I would suggest you do both crossovers, and upgrade the caps in the tweeter with a better cap, while your at it.Testing
Testing
Testing -
although it is very hard to tell I would bet that someone tried to run 120v through the binding post....
Crap!:eek:
But I would suggest you do both crossovers, and upgrade the caps in the tweeter with a better cap, while your at it.although it is very hard to tell I would bet that someone tried to run 120v through the binding post...."if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
Top-Hat-Man!
It's not worth it!! :exclaim:
Well, I only say that since it doesn't look like much fun for you. :razz:
Good to see you back here, Johnny, where ya been? -
teekay0007 wrote: »Top-Hat-Man!
Thanks, I'll make it fun!!
The summers are usually full of gigs (drumming) and when not on the road, my wife and youngest son get most of me. My 18 year old son leaves for the Marines on August 26th, so we have a lot on out minds. I still peep in and thanks to Ken, I will get this problem solved. Just waiting to see if he suggests doing both sides and if he thinks some change with the tweeters should be made. We like the RT2000i's a bunch and want them to last as long as possible, so here I go!! lol"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
I will let the person doing the repair tell me that and if he says do both and upgrade anything, then I will do so. Thanks
So you want 1 speaker with possibly weak/warn, and certainly older caps in it, and new caps in the other speaker?
Because that is exactly what you will have if they don't do both.
Hey different strokes I guess.:cheesygrin:Testing
Testing
Testing -
They aren't worth the costs involved in my opinion. Best to part out the usable stuff and seek out another set....or something else.HT SYSTEM-
lsi 9's -
Thanks to one of our members (not sure if he wants his name set out there??) I am back up and running. I was treated not like a customer, but as a friend and I feel so lucky that this person took the time to fix the problem and did it very fast. Hats off and this forum ROCKS!!"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
I have extra crossovers from my RT 35i's if you want to give them a shot. I only bought the bookshelves to use as replacements on my RT3000p's. The RT2000p's sound great! Hope you're enjoying them!
Hi new to the form polk audio technician recommended this form I need RT 2000 I crossovers can somebody help
Gilmour1@hotmail.com -
Are yours missing?Political Correctness'.........defined
President of Club Polk -
No but they are burned up
Completely burned up or just a resistor ? Big difference....and if they are completely burned up requiring totally NEW crossovers, the costs involved for both speakers will be more than they are worth.
Maybe post a pic of them when you get them removed.HT SYSTEM-
lsi 9's -
You see used RT2000 speakers for sale relatively dirt-cheap.
Like Tony said, post some pics. Chances are much greater than not that your crossovers can be repaired, even upgraded.Political Correctness'.........defined
More back story and more pics of better quality needed
I will post a pic over the weekend
Ok here's the pics and the specs of the crossovers for my RT 2000 I can anybody help
Also can these be upgraded?
I'm no expert, but given the damage done on that board, I wouldn't trust anything being left there. New ones are in order imho....but do you really want to spend that coin ? Especially knowing they were abused like that, some drivers too may have been blown your not aware of yet.
My take is to keep them as parts and find another pair in good working condition. You can usually find them under 200 bucks if your dead set on the same speakers.HT SYSTEM-
